Hey Dagoose,
three days with nightmare and thinking with you all about the hum...
1. yes, removing all ac from the case will be the first step.
Usually it wouldnt be bad replacing the toroid and rectivers to an external power case. Why not. My D a n g e r o u s music machines have all external power sections...
1b. Perhaps the Elcos on both PCBs must be extern too that just linear nonpulsating current acrosses the circuit.
2. I found out that theres something wrong with the direct current (dc) if i use a blind resistor on the bottom. the problem is that the elco trys to fill the pulsating ac holes and with the blind resistors the elco is anloading to fast that theres a litle hole which increases a litle trafo hum... i will setup up the blind resistors to the power switch that it will recharge if i switch the power switch off.
3. The rest hum i think is the electric noise field of the toroid. Theres need for mumetall around the toroid and all the ac pulsating stuff.
4. In my case i rective 24vac to dc for the LED power switch near the "filter high section". The rectiver is to near to the filter pots which increases hum too. Theres need to put it more near the toroid too and shield it with mumetall. Perhaps steel will do this job too.
5. One Star grounding
6. If step 2. doesnt work perhaps we need bigger elcos which can linear the dc current better.
7. twisting the ac and dc cables.
That are the 7 Hum aspects i thought about and i am think this will help to solve the hum problem.
Remember that the Powerpcb usually is for mono use and the stereo use causes that the ac rectiving is near to the input/output trannys.
The second better think on the mono use is that there can be more space between toroid and i/o trannys and the dc will be more linear cause, i think.
(- Perhaps the gyraf pcb and suggested toroid does not load the elcos perfectly or the elcos have problems to linear the direct current if you use two power pcbs parallel in stereo mode... i must try that out with removing the blind resistors or bigger elcos)
Right now i have -65db on the right channel! I want to get it down to about -80db with this todo list!
There IS hope!
Aaron
