alexc said:For my external tube PSUs I used aviation mic/headset type connectors. Cheap and cheerful but quite rugged. They have screw locking rings. You can see them on ebay
They come in 2 sizes for 7 pin : I use the larger ones for high voltage. The smaller ones are OK for low voltage, low current apps.
They are cheap and you can also get an extra heavy duty version in 4-pin (I use for high current discrete class A amps).
The 4pin has goodly wide spaced pins and can carry some decent current. It's quite large but still fits nicely on a 1-ru rear panel.
The 7pin version is somewhat less spaced but still easy to insulate the solder pins with heatshrink for safety.
I wouldn't use xlr type connectors with small pin spacings for psu cabling (except for tube mics!) - these are quite a bit larger than the xlr multi pin types and much more suitable imho.
As usual, for the cheaper types, you can only get male chassis-mount types, and female line types, so there is the safety issue regarding the possibility of powering up the psu without the cable connected ie. PSU end male chassis-mount pins exposed and live.
You can get them with a 'safety cap' hanging off the chassis-mount connector or one can make the cable captive (fixed and not removable) at the PSU end.
My stuff is not made-for-sale so it's not an issue for me.
kambo said:manley slam has a nice psu connector...
and it doesnt look like u r connecting your boat to your industrial cement mixer!
