Good questions. None of the XFRs are PCB mounted (maybe v2 of the PCB?). That would have forced the use of a 2RU case. The VTB1847 is fine and fits in a 1RU (mine is in Dan's case and fits OK). You can use the VTB1148 as well. Reason I used the VTB1847 is because of the colour coded flying leads and I wanted minimal soldering as well as ease of mating to PCB.electrochronic said:Question on the output TX mounting , assuming the use of a 1 RU case.
Is the EZ1084eq PCB setup for tx mounting on the board with a VTB1847 Carnhill and / or
can the VTB1148 narrow board version be used and fastened to the side of a 1 RU case ?
The input XFR can be mounted on the side of the case. It has 2 screws that you can use to hold it in place.
Although I designed the project to be as easy as possible to build from beginner to expert, I presumed that those with more experience would be able to sub parts they know could work.which is suggested and will either both work as intended ?
They are both spec'd the same. I get the feeling you are comfortable soldering leads to the XFR so get the VTB1148.
Yes correct. Off board but inside case.just looked at the PCB pic on earlier thread ( link below), looks like output transformer are mechanically
mounted off board, is this correct ?
http://www.circlesound.ca/images/EZ1084EQ%20Final.jpg
The board is about 16in by 7in. you have some room on the right side where the Power and Hipass switches are. You have plenty of room for the XFRs in the back assuming the same size case.What are PCB board dimensions ? planning layout in suitable 1 RU case ?
I'm almost finished doing the build guide. I'll try and post some pictures of outside and insides here.
Jim
