thebigskinny said:Id like 2 boards pls when do you think you'll be doing them?
I can reserve 2 boards for you. They should be arriving soon. I can send you a PM or PM me your email address as well as shipping info etc.
Jim
Dr_J said:Hi Jim,
i'm in for 2 boards! Would be great! Thanks!
ROCK-ON!
thebigskinny said:Cheers Jim! Would consider 4 boards but not sure what the price is!
Pm me!
Did you check out the knobs ChuckD hasyodermr said:Well yes and no. I like the double bar knob for these type of switches, red is typical for gain. In the end don't really like them... or my crude paint job ... so the search continues. If anyone wants them, contact me. They were .35c ea.
M
wave said:Oh and Jim,
I'm in for 2 boards as well. Can you pm me the info/price?
thanks!
Nickos said:Do you think that this board can be used to implement a Eq section in a completed EZ1290 preamp?
I don't need a line input, but it would be great to have the eq after the pre.
Someone said before that this can be probably done but without the schematics I can't find how.
Bluzzi said:Yes this can be done. The 1290 is part of a full 1084. There are redundant components in the 1290 so you would have to tap into the right spots on the 1290. The EZ1084EQ already has the ability to incorporate an add on mike input PCB (made by Madriaanse as well). However one could use the same entry points and tap into the 1290.
You would have to break the correct traces and pass the signal into the 1084. If you wanted to retain the 1290's capabilities as standalone mike pre, you would have to put a switch to reconnect the cut traces.
Right now I don't have time to look at the schematic but I'll take a look asap and get back to you. Don't be shy to remind me if I don't.
Jim
kogstudio said:Hey there,
can anyone confirm for me the model/part # for the Output XFR screw/nuts
The BOM i have doesn't say what they are.. and I wanna get it right
Chris
jandoste said:Hey Jim,
I hope you got some Boards for selling?
I would love to build two 1084....
yodermr said:Yes that's all me. DIY with a passion for bigger and better each time.
The build was easy but I have been through a few learning projects over the years. I did end up having someone build a 5mm wrench to fix a switch.. just try to find one or risk using needle nose when the switch is installed -yuk. Caution on using weak/ thin resistor leads in place of the pins that came with them - They bend and drop inside the switch! Very easy fix with the right tools.
For the typical DIY'er, suggest you offer a "round hole" alternative power switch part #. Can't do square hole with a home drill. Nice to have friends with access to a Plasma Cutter though
Happy to offer up the laser engraving file to anyone interested, modify if they want or just do it for them. Any local area engraver with a Laser Engraver machine and CorelDraw could use it. I set it up to provide drill hole centers. Pretty easy to adjust for knob diameter. Catch my labeling screw up? ???
BTW - Anyone got a source for Neve'ish double bar knobs? Can't find the surplus site that I got these from and I want a matching pair of ez1084s!!
