PeterL said:How much are these? I could be in for a pair.
Sent you a PM.
Jim
dandeurloo said:I started building mine last night. I got the AML kit and the TAW kit. Super easy!
Obviously I will be using my case which I have plenty of! Just need to get some resistors and this will be ready to go in my rack.
dandeurloo said:Ok, I got it going and sounds good from the simple test I have done. I need to Bias it but don't have a scope. Can someone who has biased theirs please get me a few voltages. I would like to have the voltages of the emitter, collector and base of the 2N3055? Thanks
Some inspiration for everyone. My cases and ChuckD's knobs!
Dubka said:Cheers mate.
I should probably point out, the hum begins before the front panel touches the rack rails and grows in volume as the unit moves deeper into the rack.. It's more like psu interference from another unit (except nothing else is switched on!!!)
Once again - ONLY WHEN HPF IS ENGAGED
Dubka said:But that's just it - nothing else is switched on!
And what's the connection with the HPF? The unit sounds fine if I don't use the HPF...
The hum gradually decreases as I lift the unit out of the rack and steadily increases as I slide it back in... So odd..
