L´Andratté
Hello Ian!
Hope this is an ok thread for my questions-
After all I feel ready to build some tube stuff and I want to build a pair of your Classic tube pre design.
I don´t have the pcb but want to experiment with p-t-p and eyelet etc. anyway, I just chose the design because it seems to achieve what I want (clean and big sound )
and is so exceptionally well documented! (other than Pultec MB1, which I first planned, maybe later)
I want to build the lo hum ver, with an external power supply, now finally my questions :
*Would you agree that HT 250 supply should completly go into the external box
with HT DC in the umbilical cord (I think so)?
*If so, what kind of smoothing/bypassing should happen in the actual audio unit?
*Heater supply AC (after elevation divider) through the umbilical directly to filaments?
*Would it be a bad idea to use an unvented (Hammond) steel chassis of
30cm*20cm*5cm (ca. 11.8"*7.8"*1.9") for two (or even four?) of the 6922 inside?
I´m shure I could cram it all inside but afraid it get´s too hot,
although it would be very convenient for me...
Sorry if this is cold coffee for you, I DID use the search function but wasn´t able to come
up with the answers for these, although I bet you have already covered this stuff somewhere!
And hats off to your work btw. your grounding paper is one of my go-to documents!
I´m s
