Marik
riggler said:I am making a couple revisions and am sending to Marik...
I looked at the prints. It will take me a couple weeks to put all the numbers together. The preliminary ideas and considerations are:
1) The Aluminum material is about 3-4 times cheaper than brass. While the labor would probably dominate the final costs, still not to overlook. We can provide any finish: blasted, polished, ground surface, Ni plated, anodized, powder coated, etc.
2) The Stainless mesh is about 1/3 cheaper than brass.
3) It would be much more cost effective to leave the grill assembly to the end customers. The across bar can be glued with JB Weld and the mesh glued with silver epoxy. Alternatively, we can do it, as well. From our side something fancy like laser or spot welding, etc. is not a problem, but will add costs. If folks decide to do the body out of brass then soldering would probably be an easier option, but then one thing to consider is that would need to be done before Ni plating (i.e. we will need to do it ourselves). Overall, the main object is securely put together structure with a good electrical contact between mesh and body, which IMO, most of the folks would be more than capable of doing.
4) The minimum quantity we could bid on is 50 sets.
Once I get some kind of feel as for what folks have in mind I can proceed with things.
Best, M
