Motivated by some of the projects i've seen (and even contributed to, in some form or another) around here and in other places, i at long last decided to strive to finalize some ideas and circuit designs i had been dabbling with, on-and-off, for the last couple of years.
While some similar ones (or not) are already available from various sources, they suffer from one or several pet peeves of mine - 15 million different component values, unnecessarily pricey parts, questionable PCB routing, thoroughly inelegant assembly & wiring, and so forth.
While some already commercially available boards do indeed exist, they seem to be intended either for one (and ONLY one) mic body / chassis (thereby complicating mechanical mounting, and/or requiring shoddy fastening solutions etc), or the list of compatible ones is not mentioned at all (despite the existence of even more than one pair of mounting holes). As an added personal challenge, one of the starting points was compatibility with as many (affordable) mic body variants as i could get my hands on, to confirm mechanical measurements.
Another one of the self-imposed requirements was to provide as many useful features as feasible, in order to make up for some of the shortcomings that some of the more affordable capsules seem to suffer from. In a couple of these cases, going full-SMD was necessary in order to manage to fit all the needed components that allow all the tone-shaping possibilities i wanted. The SMD ones i'm seriously considering offering fully-populated (for the most part, anyway - unless otherwise requested).
If anyone has any questions about my design choices, i'll gladly strive to answer and justify them - there's always a (good?) chance you might not like / agree with my responses, though
As at least some of you are probably aware, I'm mostly driven by practicality and engineering common-sense. "Vintage accuracy"-fetishists, this is not for you
This is for people who would rather prefer to get things working with minimal fussing about, without ten-mile-long BOMs and "esoteric" parts sourced from 20 separate suppliers. Sure, if you enjoy experimenting, be my guest and have at it
But if all you want is to put these together, solder the capsule / XLR / transformer (where applicable) wires, here ya go!
"OpAmp Alice" - cardioid-only
- single-PCB design, all SMD
- OPA2991-based (~1.2mA typical current draw in total)
- 36V supply - all the dynamic range you can handle, and then some!
- no capsule coupling capacitor
- impedance-balanced output
- suitable for electret or externally-biased capsules
- passive capsule bias filtering
- output-disconnect circuit to prevent spurious power-up/down noises
- option for attenuator pad (lowering capsule voltage)
- option for low-cut / high-pass (~120Hz, 2nd-order)
- pad & low-cut can either be vertical-mount switches (mechanical modifications to body tube needed), or internal 0.1" pin-headers & jumper-links
- option for RK47 5kHz notch & slight boost at 10k-and-over
- option for K67/K87 8-10kHz notch
- streamlined BOM: only four(!) different resistor values & three(!) different capacitor values (electrolytics & C0G/NP0 ceramics)
- fits Alctron MC001, Apex 435, BM700, BM800, Focusrite CM25 mk3 (possibly earlier ones as well), M-Audio Nova, MXL 440, MXL 2001, MXL 2006, sE 2200A, t.bone SC400, t.Bone SC450
A little "sneak preview" - ignore the slightly messy silkscreen markings, i haven't yet spent the time to (also) make that side of things "pretty". But i'll get to that too...
![Screenshot 2024-06-24 154358.png Screenshot 2024-06-24 154358.png](https://cdn.imagearchive.com/groupdiy/data/attachments/83/83221-5eb89faee9412e5e663e61f3fdfcdf7c.jpg)
"OpAmp Alice" - multipattern
- suitable for externally-biased capsules only
- all of the above-mentioned features PLUS...
- interconnected three-board construction
- sturdy design, trivial wiring & assembly (capsule & XLR wires only)
- CMOS-based capsule bias charge-pump
- cardioid / omni / fig-8
- pattern selection can also be a mechanical switch, or an internal pin header & jumper-link
![OPAlice_multi.png OPAlice_multi.png](https://cdn.imagearchive.com/groupdiy/data/attachments/81/81958-e51aad31ea5615f574e1005340e9d8ed.jpg)
U87A with 21st-century design sensibilities - unleash the hatred![Laugh :LOL: :LOL:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
- same mechanical compatibility as the "OpAmp Alice" designs
- all through-hole components (on the audio boards)
- power supply reconfigured for maximum noise filtering
- (up to) ~32V available for the JFET
- pattern switching revised, one single 1Gohm required overall
- no Teflon / PTFE isolation pins needed
- streamlined BOM: only five different resistor values (versus the original's TEN, only in the audio section), & four different capacitor values (versus the original's EIGHT; electrolytics, film & C0G/NP0 ceramics)
- pad / low-cut / pattern can be switches (mechanical modifications to body tube needed), or internal 0.1" pin-headers & jumper-links
- output wiring option available for single-secondary / center-tapped secondary / dual secondary transformer
![Screenshot 2024-06-05 22.13.00.png Screenshot 2024-06-05 22.13.00.png](https://cdn.imagearchive.com/groupdiy/data/attachments/81/81982-764b784ab15ff764ab0fc7fd9631b8e5.jpg)
FET847 - the engineeringly-sane version
- single-layer, optimized routing - top copper layer unnecessary, if one pays even a modicum of attention to component placement / layout
- design flaws of the original project corrected
- optimized BOM: (more) conventional component footprints
FET847 multipattern
- same board set as U87A
- only needs one wire jumper, and not-populating the feedback components
CMOS-based capsule bias oscillator
- all SMD
- 40106-based
- facility for capsule voltage attenuation / pad
- facility for pattern switch
Currently i'm still "polishing" some final board details (mainly on the mechanical side of things), and i should have a first batch of prototype boards in hand in the very near future, so stay tuned!
Unless otherwise requested, i was thinking it's probably most practical to offer the SMD boards ready-assembled, and the through-hole ones as-they-are (so you can trick them out with your favourite Dale resistors and whatever else gets your rocks off spending money on). It would also likely be nice of me to put together some build guides in some form or another; i would expect them to be more informative than pretty though, so you've been warned![Beaming face with smiling eyes :grin: 😁](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f601.png)
But for the time being, this is intended mainly just to gauge if or whatever interest there may or may not be around here, for things like these. Of course, all of these projects and boards are still pending physical prototyping, so keep that in mind - i will of course update descriptions and details if need be, and I'll gladly listen to whatever thoughts or concerns wiser people than i might have. Just try not to be offended in case i end up shooting them down due to... y'know... sanity, and other such "heathenistic" reasons![Laugh :LOL: :LOL:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Edited 05.06.2024 - added a couple other board screenshots
Edited 06.06.2024 - corrected a couple numbers & typos
Edited 17.06.2024 - added optional low-pass to FET847 cardioid-only & updated board screenshot
Edited 24.06.2024 - added MXL 440 mounting holes, updated board screenshots
FET847 multipattern
- all SMD
- 40106-based
