[quote author="dissonantstring"]i've tried the 22K resistor between the gate of Q8 and the wiper of the 10K pot, which helps a little, but there's still oscillation. [/quote]
I used a 22k not for its value, but because it was the only big carbon comp resistor I had at the studio when I was testing it out. I was looking for a smaller value, but since this design just has heaps and heaps of gain it didn't do any harm, and it stopped the oscillation completely in my build. I can turn the pot all the way up, however it never gets turned up past 9 o'clock due the onset of clipping with any normal mic and source.
It's not very versatile, but I love the way this pre pushes a distorted guitar to the front of the mix.
[quote author="dissonantstring"] i tried pulling C1 as Fabio suggested and now my unit does not pass any audio.[/quote]
:shock: That doesn't make sense. That should only affect the feedback around the first stage. That cap is around part of the source resistor,and the signal is being taken from the drain to the output transistor. It shouldn't have killed your output. That's truly weird.
Here's a thought, variable feedback using a pot in place of the source resistor. Hang the cap off the wiper to ground , so you can adjust how much of the source resistor is bypassed, if any.
