Deepdark
Svm900 will fit
0dbfs said:C1 as in the 4pF NFB cap? That cap certainly provides some NFB back into the gate portion which in my understanding stabilizes the amp, reduces gain, and I believe it also reduces output impedance... I'll read up in my RDH4 on NFB maths...RuudNL said:What is the function of C1 ("Tuned to taste")?
How do we "tune" this?
For tuning the specific value try some different values, sweep the DUT / graph the results for quantitative measurements, listen in context for qualitative measurements...
I don't know of another procedure used by the OEM but would like to hear about it if anyone knows or any additional discussion on the topic for that matter.
Cheers!
-jb
That's a great observation and yes the polarization voltage supplied to the capsule is in the area of "slightly less than 48V" like the KM84 or vintage U87 circuits which both use different capsules biased at that voltage. It is my understanding that the 60V (or perhaps even 70V) polarization spec is a max value before the diaphragm becomes sucked to the backplate due to electrostatic attraction.geebeeVIE said:Sorry for the dumb question, but what polarization voltage does it supply to the capsule?
If it does supply, like the KM84, only "less then 48V" - it will not be suitable for any of the mentioned capsules as they ask for 60V polarization voltage to work to their specifications....
I think that would turn out similar to the original with the 7586 paired to the BV107 / CM5722 from Cinemag in what looks like a fairly standard plate-loaded self-bias circuit (close-to-stock chinese PSU would work well since it's not fixed bias). You could change the polarization scheme slightly such that you polarize the backplate and take the signal directly from the diaphragm while losing the capsule-to-grid blocking cap. Looks like the U64 uses a 51V capsule polarization divided down from 120V so you could also tune that as desired You could probably P2P it pretty easily too in a small body like this one for tight placement and a fixed omni/card pattern too.bruno2000 said:I have a collection of U64 mics (which I love), and consequently have a stash of NOS 7586 tubes. Thought about doing something like this with a 47 or 49 capsule, but using the 7586 tube. Thoughts?
Bruno2000
poctop said:KDOKELeeDO, all gone , :'(
thanks To All and Enjoy your FET847 Project ,
Dan,
Spencerleehorton said:Ah ok,
So could that be put to a switch and tuned to taste for bass?
Spence.
