Hi guys. Sorry for not being too present in this discussion. I've just wrapped up a recording project that took a couple of months and my brain is mush. It's also summer here in North Idaho and I find it quite difficult to sit in my office when it is so nice outside. IMO, there are some good questions and well written replies in this thread (hell, in The Lab in general, which seperates it from most other forums), and I don't know how much I can contribute to this discussion.
Perhaps you count yourself as one, but you can be hardly put in the same bucket with the crowd that reveres the unidirectional RCA cable.
Well no, I don't count myself in with that crowd. But don't get me wrong, if I could hear a difference by reversing direction on an RCA cable, I find the best sounding direction (to me) and use it. I've tried. I don't hear a difference. YMMV. I do hear a difference in interconnects and other cabling and it is not within my technical grasp to explain objectively why this could be so. None the less, I use the cabling that I think sounds the best. I try to keep an open mind on this stuff, but my mind is a finite space and I don't try to keep up with all that is going on in the audio industry.
I've spent a lot of money of test equipment. I've spent a lot of money on listening set-ups. I use them both in the design and evaluation process of my work. My designs tend to start with concepts rooted in an intuitive approach to solving a problem or an operational situation. The solutions to those problems or situations tend to be rooted in the technical/engineering side of things. In my little world there needs to be balance between the two.
So I have a good listening set-up in my lab/office, another in my house, and I do recordings in a studio that has really nice stuff in it. I design equipment to use in those systems, in the studios, or in the remote recording rig that I use to do live concert recordings because it is what sounds or functions the best to me.
I also have a large tech library (35 years of collecting audio books) and I think this is a very important aspect of learning this stuff. I also do a lot of experimentation, listening to a ton of music (real and reproduced) every day, and have a lot of enegry and time to work on this stuff. That all helps too.
I design circuits on paper and build them on the bench. I make sure that they are working and behaving themselves with my test equipment. If all is well, I start listening and tweaking the design until I come up with what I feel sounds the best. I measure the circuit again to insure that it is still well behaved and operating well within the safe operating area of its components. I typically then run it though tests that simulate real-world extreme operating conditions to see that it performs propely under those circumstances. Adjust things if needed. Then I listen a bunch more, and finally, take it out into the world to see how it does. That's when it goes to other people to find out how a design works for them.
Fred, I don't believe you would choose to line up with the latter!
More on the point though, from a few of the things I have seen, I suspect you to be a FET fancier... If so, is there an objective case for FET superiority in audio applications?
Alan, yes I am a FET fancier... actually a JFET fancier. I started designing stuff with tubes back in 1970. I also messed around with BJT designs which I found far less rewarding sonically and a lot more demanding of me as a designer. That was my limitation as a designer. I had some good mentors in this process (a great designer named Geoff Cook, and another name Bascom H King) who were leagues ahead of me in knowledge, experience, and IQ. One of the really important things that I learned from them was about listening as part of the design process.
Somewhere around the mid 1970's a comany called Crystalonics came out with a really good low noise JFET called the C413 (which became the 2N6550). It was the first solid-state device that you could pretty much simply hook-up (like a triode) and have it pass totally acceptable signal through-out the audio passband. It was extremely quite, unlike most single tube circuits, and it sounded great all be itself. We used it for front-end diff-amps, and all by itself as a moving coil cartridge pre-preamp.
Later Siliconix came out with V-Channel MOSFET which to me, where the first really good sounding MOSFETs out there. We used the VMP-1 a lot as output devices in discrete opamps. I have also used depletion mode MOSFET in place of JFETs at various times, but I haven't liked the results as much as the JFETs. But you can get 500 volt depletion mode MOSFETs and you can't do that with JFETs.
One of the coolest things about JFETs to me (being a tube designer) is that you can get P devices. That really opens up the world of topologies to one as a designer, compared to working with tubes. So with modern JFET devices, I can take some of the design approaches and ideas that I use as a tube design and use them in JFET designs, but to have the added flexibility of P and N devices. The currently available (at least for now) JFET devices like the 2SK170/2SJ74 and the 2SK389/2SJ103 are large geometery devices with high Gm (22 mS) and low pinch off voltages. These work really well for audio circuits, IMO. Building a simple three-stage amplifer with these devices and running it open loop can result in an amplifier that is flat out to 10-20 KHz and that has very low distortion. I've never been able to do that with BJT. I do it with tubes all the time. Yes there is local degeneration with the JFET designs as there is with some BJT and with tubes. But without global negative feedback, the JFET and tube designs function acceptable within the audio passband. The BJT designs never have (at least not my BJT designs).
Because these designs tend to be more linear without global negative feedback they have a better "feel" to me as a designer. They are easier to work with, being more stable, less prone to becoming RF detectors, and do not suffer from the breakdown characteristics of BJT. JFETs are voltage controlled devices and do not require large amounts of drive current (although one needs to be aware of the gate capacitance, which requires low source Z and symetrical source/sinking of drive current for symetrical slew rate performance). I love not having to worry about using darlingtion connected driver stages, or dealing with the more complicated bias requirements, and SOA consideration of BJT.
However, the bottom line for me is that using JFETs I can design circuits that are simple, stable, sound good (to me at least), and still perform all the functions needed in the pro audio world. The fact that these same circuits perform well the audiophile world as well, says something to me.
When mixing a project it is always about how that mix will translate out there in the real world. We work hard at building mixing systems and rooms that allow us to build a mix that sounds good to us right then and there during the mix session. We then hope that the results will translate well outside of that room. For me, designing circuits is kind of like that... If I do it correctly, then it will sound good to me in my listening set-up, measure well on my test bench, and translate well out there in the real world. Designing with JFETs and tubes consistantly produces those results for me. Using BJTs, IC opamps, and (so far) MOSFETs does not provide the same results for me. That's probably a limitation of mine as a designer. As a designer, YMMV.
My recommendation is that you play around with this stuff in its most basic form and find approaches that feel and sound intuitively correct to you. I'm not sure you will ever find absolute answers to questions like "Are there advantanges to using FETs over BJTs in audio circuits." Nor will you find absolute answers to is Cabernet better than Merlo. It a personal thing. The answer is formed in one's own brain and that makes it subjective.
Sorry for the long post. The morning coffee kicked in.
Cheers.
