[Finished] ssl9k + Harrison Ford Filter
G-Sun
Norway
Well, sort of finished anyway.
I proud present my first real DIY-project:
- 2 ch ssl9k, with JML Go-between and 1ch DI
- 2 ch Harrison Ford Filter
The pre and filter can be linked or used as separate units
The knobs/pots are:
DI, Ø, Pad, Gain (2x), link on/off, Lowpass, highpass, bypass (filter) (2x), power
The link is wired from the jacks, so it's not bypassing the out/in balancing. Could just use a jack on the back or my patchbay, but.. think this is more elegant.
G-Sun
Norway
More pictures here
G-Sun
Norway
To do:
- Replace coupling cap on the ssl9k x4 with wima or pio caps
- Fix painting on the frontpanel
- Make front graphics and apply
Sound, impression:
The ssl9 sound clean, tons of gain, but a tad dull/ boring. Awaiting upgrade of the coupling-caps. See: http://www.groupdiy.com/index.php?topic=11320.msg615693#msg615693
The Filter sounds very good to me, but need some modding regarding corner-fq. see: http://www.groupdiy.com/index.php?topic=46390.msg615795#msg615795
Difficulties:
Been many difficulties with this project. When I started I was very newbie, had to ask for everything, and made some mistakes on the way.
Notice the +48 light on ch1 and 2, they're supposed to be identical, but not enough experience with metal and the drill :)
Anyone else have put 21 wires into a JML PSU? Not really recommended.
Summary:
A lot, a lot of work, but great experience. Next project will definitively be one that's easier to build..
Thanks a lot to all you guys that made it possible for me to do this project: Design, schematic, pcbs, parts and most of all -answering my endless row of newbie-questins :) Thanks a lot!
bruno2000
Atlanta GA
That looks great!  You should have seen MY first projects (MANY years ago).
My 9Ks are clear and bright.  Might be the coupling caps, maybe something else.
Like fine wine, you'll get better with age.  Just keep at it, and you'll learn as you go.
What's next?  ;o)
Bruno2000
Winnipeg Mb Canada
I like the regulator heatsinks , makes contact with the case even , nice !
Who's filter boards are those ?
G-Sun
Norway
Thanks Bruno! BTW: Thanks for all your help on the way! Would have been nearly impossible without you guys helping out :)
God to hear. Mine is usable, and that will have to do for now.
What's next?  ;o)
Thank you!
Next:
a) Nothing
DIY takes just so much time and money. and I have a lot of other things to focus on right now.
b) 2-1176, 2ch Calrec EQ, G9 Tube pre :)
G-Sun
Norway
Thanks! The regulators are not really connected yet. Havn't tested how hot they get. Best would be to fasten them with screws to the bottom I think.
Filters: http://www.groupdiy.com/index.php?topic=46390.0
