The cable is shielded with the helix twist, like Belden Media Twist cable.At 55 secs, the video shows what looks like a semiconductive sheath on the inside of the blue jacket, but no way to connect this to ground.
Is this cable shielded or not?
This is an interconnect cable, not a speaker cable.He removes the outer shell with what seems a pro UTP stripper, and then resorts to the venerable 2$ wire stripper to do the wires inside...
LOL. I mean, who are they fooling with their complicated looking black magic mojo?
Also, there seems to be very little copper in this cable. I would never use that as a speaker cable.
I accidentally found this via a DuckDuckGo search and I THINK it's posted by "WireWorld":
Shrug.....should be a similar process to set it up for XLR terminations.
Bri
PS, in that video, I saw mention of "arrows on the cable". Guess it's another example of
"the audio must flow in THIS direction" voodoo.
Thanks, but this wire is perfectly acceptable for long, non-critical AV audio runs. And that's exactly what I'm doing with it. It was cheap and plentiful.I would suggest you buy some cable from a reputable brand such as Belden who build cable properly, and far cheaper by the way.
I use the same or similar - they have variable tension screw as well and can easily strip 4 cables at once - I have 2 both set for different cable thicknesses. The outer sheath stripping, for cables like that, I use a rotary blade sheath cutter which has 4 cable diameters on a rotating stop-block to cut varying sized sheaths. I use it for all my mic cables and also network cables. I removed the second blade that cuts the inner core sheath otherwise it’s not suitable for mic or network cables - it’s designed for coax single core - very quick and very neat, you just set the size of the outer jacket on the insert, clip it over the cable and rotate once.View attachment 116408
I use something like this for stripping 2/3/4 core flat wires.
You can cut a meter sample from your wire, bring to a local electrical hardware shop and try before purchase.
Regards
I'm trying to find a good stripper tool so I can start using it.
The outer sheath of the three flat cable sets is round so for the outer sheath only, the clip and rotate sheath stripper will work fine.Howdy! I use this type of wire stripper for that sort of task. It can strip more than one small wire at a time. Sometimes it takes two swipes to do the job - first to remove the outer insulation, and second to remove the insulation on the smaller wires inside.
Most wire strippers are made for round cable, such as the one used for prepping RG6 , RG58, and RG11 cable someone else suggested. Those are not good for stripping flat insulation as they are designed to clamp and spin around a round conductor, such as RG6. And that is just MY take, having used them for prepping radio transmission lines. Good luck. James / K8JHR
Thanks. These might do the trick but I'm having trouble finding them in the USA.Well I'm old skool and bought a pair of these about 25 years ago.
I don't like most of the "Automatic" types as you have no control over what they do, and sometimes they do what you don't want them to do.
These you set by hand for each individual job.
I am so used to doing that, I never mess up.
https://www.tester.co.uk/itl-insulated-end-wire-strippers
Just use thermal wire strippers.I recently purchased 100 meters of WireWorld Oasis 8 interconnect cable. It has 4 flat conductors( see picture below)
Any suggestions?
Thanks in advance.
Michael MacDonald
AlgoRhythms Mastering
" Electrons, having mass, flow better when heading downhill."Also, it's also VERY important to have source components above receiving components for the ultimate audiophile tweek.
Thanks. I learned something today.That is misusing the term "shield." Twisting is not shielding. You can buy shielded or unshielded MediaTwist cable. A shield means continuous coaxial coverage, either with foil, braid, or overlapping spiral winding.
The proper term for that cable is unshielded twisted triple.
You do realize that was satire, right?" Electrons, having mass, flow better when heading downhill."
HA!HA!HA!
So much stupid ******** in eight words.
You made my day !))
Been a long time I did not laugh that much !
More seriously, I've been here since many years, but I never could imagine to read such crap one day on Group DIY...
never used one before. will look at that as an option if it makes sense price wise.Just use thermal wire strippers.
