Has anyone measured the phantom voltage and current output of the Focusrite Scarlett 2i2 (2nd Gen) USB Audio Interface?
I have only found this from searches reply #9https://www.gearslutz.com/board/low-end-theory/778381-focusrite-scarlett-2i2-cad-m179-performance.html 9.5ma for one channel 19ma for both or 9.5ma total for both channels?
I don't want to buy it, test it and then return it.
Found this https://us.focusrite.com/usb-audio-interfaces/scarlett-2i2/specifications
But does it measure 48VDC? Does it supply 10ma per channel? The 48V is on the front panel section but not in the more detailed list below it.
It would be nice to know the real voltage and max current for each channel and all channels on.
The older microphones like the early u87 , KM8x need 48VD to work the best. Other microphones can use some current.
I am looking at this because it is reported to run in linux.
