FS: EQ250A Stereo sets (Fabio's Sontec)
petermontg
Ireland
I have some boards left over from a min order.
All 5 filters are set on one board.
Boards are 4 layers heavy duty. (Very little flex)
Each filter has optional bypass. If you don't want filter bypass it's just a matter of jumping the position. If you build a stereo ganged  unit, one set of relays can be used.
Extra position for the center tap.
Amps have true bypass and DOA footprint is kept.
Some extra position on the amps to extend the EQ out to 7 band with standalone shelves. (I currently don't have any in stock but can be ordered if needed.)
Some extra positions to help grounding if needed.
I still have the files to build the filter selection and rev log pot to switch and all the original files from the project.
Which I will include when purchase.
I will post some detailed photos when back in the house later.
I am asking 100Euro a stereo set with free P&P.
Best Regards.
Peter
I will offer as much support as I can but if you have experience it should be a breeze of a project for you. The hardest part is building those resistor chains. PSU are 337/317 and toroidal is available from hairball.
