Rob Flinn
Hello Folks
I've been thinking about some functional enhancements to my MCI 428b console. One thing I like to do is use stereo compressors on subgroups. The problem is that the MCI 428b doesn't have subgroups.
My idea was to make a stereo return module that would occupy the space below where the patchbays are. That way I could create a stereo sub mix through the tape routing pairs (my desk has a mod that enables panning to the tape routing pairs), come out of the line outs/tape sends on the patchbay through a compressor & into the added stereo return module.
Since the MCI has quad outputs that are summed to make the stereo output I was considering disconnecting the back bus from the back summing amps & using them to sum my stereo returns which then get summed with the front bus to make my stereo bus. Is this a good idea or should I make a dedicated summing amp for the stereo returns. I don't use the back bus for anything else so I just figured that this would use it for something.
I was thinking I could hook the balanced inputs to the stereo returns parallel to the tape sends on the patchbay. That way I would have say the 1st 10 pairs of tape routing also normalised to the stereo returns. This gives me an insert point to them. Since when tracking I would not use the st subgroups & when mixing I wouldn't be sending to tape I can't see a problem. Question - would this give me an impedance issue paralleling them to the tape/PT inputs.
I would like to have a solo function on the subgroups. I was thinking that I could have a standard solo function for the stereo pairs using relays for each pair & another relay to switch off the mono channels by disconnecting the front bus. The only problem with this is that I think if I solo a st pair & a mono channel I think the mono channel won't be heard. So I'm trying to find a way to make it part of the whole solo system on the console, needs a bit of thinking about. .
Anyway above is a preliminary diagram for one half of a st pair. The resistor after the 220u & before the mute switch is the 10k summing resistor.
Things I'm not too sure about are the values & polarities of the caps, & if I actually need the 2u2 at all considering that the dc is blocked by the 100u preceding the fader.
I would add that I have taken the basic building blocks from Doug Selfs Book, small signal Audio Design. Some of the things like the muting switch arrangement look a bit radical, but according to Doug this is a lower noise than decking the 10k with it still connected to the bus. If anybody has any arguements for other topologies, critisms or enhancements I would be interested to hear them.
