frazzman
Hi all,
I have a GAP Pre73 (Chinese neve 1073 mic ore clone) that decided to bight the dust moments before a session today. Powers on with a very very faint LED and has that distinct burning smell. These units are apparently pretty well known for having a lousy PSU section. It's powered by an external 24vAC adaptor.
I popped the lid off and took some measurements at the output of the PSU at the 24V and 48v connectors - both measured fine. I noticed that there was no burning smell with the mic pre PCB disconnected.
I then reconnected the mic pre PCB to the PSU board and took measurements at R8 (+24v test point) - this is only measuring 2.4V. Similar story on the 48v measurement.
I noticed that there is a 270R 5W resistor on the PSU board that gets extremely hot. Users have mentioned this as a culprit in the past but it tests ok here at least on the DMM
Could I be right in that there is possibly a short on the mic pre PCB or the PSU is crapping out under load?
Any ideas ?
Any ideas ?
