gar2520 build thread
Thank you Gary, considering I`m just starting I feel a little proud  :p
I was most concerned about shorting the pads closest to the millmax pins to the millmax sockets. In retrospect, after looking more at the photos, it looks like it wouldn`t have mattered anyways, as they are traced anywways?
So I recently built 6 gar2520's for a pair of fc526's, and 5 worked out great. After realizing I'd put the BD transistors in the wrong spots, I decided to replace all the caps/ transistors/diodes to be safe. I didnt replace the resistors as they all tested fine.
After A/Bing the new op amp to the others I've noticed the rebuilt op amp sounds like it has a HPF.
The compressors definitely aren't an issue as they work great with good opamps.
Any Ideas on what could be causing this?
Dear people,
I've built around 12 x 2520 and 6 x1731. They all work, verified in VP25,VP26,AnalogAllstars,and TB550a projects.
I also happen to have an Api2500 stereo compressor that lost one 2520 opamp. Well,you know..
I made sure I could fit the "short legged"  gar2520 in (bij moving/resoldering a cap that is in the way,under the opamp) So far so good,verified with the one still working APi2520 opamp.
I inserted a Gar2520,switched on and was greeted by massive noise. Not good.  Tried another one,same result. Tried a third,same noise. Note that all these opamps were tested,and working. Trying them in a vp25 again, which verified that they still  work properly.
I then put in a Gar2520 whilst the machine was on.Yes I should'nt have done that.. But it worked,and sounded fine. Weird..? I then switched off the compressor, switched it on again,and again the loud noise was there. It was even audible when I switched to bypass (2500 uses relais for that),so it must be quite spikey... Trying that opamp in a vp25 again verified that it is still in a good shape.
Has anyone encountered such a problem in the 2500 compressor? Is there a solution?
Thank you,
Pieter
Can anyone (Gary/Gar381) tell me what surface finish is used for the two DOA PCBs available from Jeff @ ClassicAPI, please?
As they're not gold plated, it is unclear whether they'll be leaded or lead-free HASL (or something else?).
Tom
OK - cheers - leaded solder it is then...
(slight sigh..)
[these days, it is as cheap to get RoHS boards as non-RoHS. Lead-free boards can be used fine with leaded solder, but not vice-versa, so I would suggest producers moving to RoHS - would not in anyway stop builders who like the lead still sticking with their old ways]
Hello everyone!
Is there a way to test 2520's & 1731's without pluging them in a module? With a DMM for exemple?
Thank you,
G
Hi, noob on building DOAs - have built a number of SCA pres, guitar amps, etc., and decided to try the gar2520.  When I power up, Q8 gets very hot quickly.  I've checked that Q7 and Q8 are in the proper locations and correctly positioned, and have been through looking for solder bridges / shorts between leads.  I know I did something wrong, would appreciate any advice on where to look.  thanks much!
BTW, have tried at +/- 16 and 15 volts, no higher.
Hey guys!
I'm working on some gar2520s and I ordered quite a few BD139-6 instead of BD139-16 by mistake - too much work right now. Do you guys think using 139-6s is negligible in this circuit?
Thanks in advance and best regards,
Mathias
Hi Mathias
The only difference is hFE.  I have used BD139-10 in the early days
of this DOA and could not hear any difference.  hFE on these outputs
is not that critical.  I never tried the -6 version.  I would use -16 guys
if you can get them but try the -6 in one and See what it sounds like.
You might be OK.
Best
GARY
Hi Gary!
Thanks for your help!
I tried one with a -6 version and this one seems to distort a little bit earlier when pushed harder than the ones with the -16s (tested in VP26s). I guess the question should have been more like "is it ok to mix BD140-16 with BD139-6, or will I face serious problems with asymmetry in the output stage?"
Best regards,
Mathias
Does anyone know if you can use 1n4149's in this instead of 4148's.
I've built 28 for a mixer and I soldered in the wrong ones already. Spec sheets seem to look more or less the same.
gar381 said:
Hi Jess
Never tried the 1n4149 but it looks like it should work.  Fire one up
and see how it sounds.
GARY
ok cheers gary, its a while before the mixer is complete though.
i read on another forum that 1n4148 is 20pf and 1n4149 is 10pf if that sheds more light?
I built my first gar2520 and it did not work. So I built 2 more and these are not working either. I dont even know where to begin to try and trouble shoot . I have a magnifing Lamp and can see pretty well that there are no shorts/Bridges. all that I can think of is maybe I got a component to hot ? I have been soldering for years, not on things quite so small but it didn't seem like I got anything to hot. Anyway any suggestions on where to begin on trouble shooting would be helpful.
Thanks much,
Thomas Thew
