kante1603
Please read this thread…..?
Greater than 10MΩ.salomonander said:can anyone tell me what input impedance these are? cheers
Tommy T said:I built my first gar2520 and it did not work. So I built 2 more and these are not working either. I dont even know where to begin to try and trouble shoot . I have a magnifing Lamp and can see pretty well that there are no shorts/Bridges. all that I can think of is maybe I got a component to hot ? I have been soldering for years, not on things quite so small but it didn't seem like I got anything to hot. Anyway any suggestions on where to begin on trouble shooting would be helpful.
Thanks much,
Thomas Thew
geardude said:Hey fellow capi enthusiasts! I'm currently having an issue with my Gar2520's- they are humming upon output with no other mic signal getting through. I've started a thread and checked for bad bridges & joints but no luck. Here's a link to my thread with more specifics. Thanks and I appreciate anyone's help and feedback! This isn't my first rodeo so to speak as I've built a handful of these before, but this is indeed my first hiccup!
http://groupdiy.com/index.php?topic=63058.0
gar381 said:At this point I would try NEW pair of outputs (Q7,Q8) and R11,R12.
Double check... Make Shure they are in the right holes and facing
the right direction as shown in the assembly manual.
Make Shure there are NO shorts between R11 and the 2 Millmax pins
next to R11s pads on the foil side of the PCB.
Best of luck
GARY
Allecstatic said:Thanks, Gary! I'll give that a shot! Are the output transistors and the r11/r12 resistors the last components in the circuit on the 2520? Just wondering if there is anything else down the stream that could have been damaged that I should just replace to be safe. Thanks again for your time. These opamp builds have been a treat!
gar381 said:Thats correct R11 and R12 are the output emitter resistors and
their junction feeds the output Millmax pin.
Do double check .... No shorts between R11 and the 2 close
Millmax pins.
GARY
Millmax pins.
GARY
gar381 said:Most unlikely that there was a bad part shipped in the Kit. There has to be a part in the
wrong position or a solder bridge somewhere. Check the diode string to make sure
they are in the correct holes and polarized correctly also make sure one of them is not
shorted from your original bad reverse of Q7&Q8. Make sure all the TO92 case
transistors are in the right holes and facing the correct way. Make sure all the resistors
are in the correct holes. Make sure none of the component leads on the top are touching.
Make sure that there are no solder bridges. Check out all of these thing with a magnifying light.
Are you feeding the DOA with the correct voltages and polarity ?
If all else fails, get a new kit and start over.
Best of luck
GARY
