Ah, so, like peak music power is about one tenth of mean.gyraf said:;D yup, I read you - but these are chinese volts, like used in auto hifi.. ;D
pvision said:I built a prototype of something similar a short while ago. Spent many happy hours listening to diodes...
The final results were really good but it needs a PCB to bring build time down to a reasonable level
https://www.bn1studio.co.uk/shop/compressors/stereo/grasshopper-valley-yellowhammer/
Nick Froome
Nick Froome
gyraf said:..for experimentation (and yes, this requires massive amounts of experimentation), it's probably easier just to solder directly to the switches?
rbuskov said:Great idea, Ian!
As for the linear approach, I really like the DIYRE 15 IPS Tape Saturation Colour: Clipping germanium diodes and a low end roll-off/bump meant to mimic the sound of analog tape. I use it all the time... not sure it actually does sound like tape but I'm a sucker for germanium diode distortion... ;D
Ricardus said:I really like the 15 IPS module myself. I think it's the most usable one.
rbuskov said:Agree.
Here's a demo of all the Colour modules from DIY RE:
https://www.youtube.com/watch?v=nbrqXS5VjTA&feature=emb_rel_end
Some are definitely more usable than others.
ToBSn said:Indeed, the DIY RE stuff looking really good.
But in this case it’s not a passive circuit for passive box.
wlinart said:Mammoth cave audio did some things like that. Here is the description, maybe there's some inspiration to get there: https://web.archive.org/web/20160219215310/http://mammothcaveaudio.com/passive-aggressive-series/
ruffrecords said:I was hoping we could do a passive only device - saves loads of problems with power supplies and so on.
ruffrecords said:That one is an active box. I have built quite a few of these in the last decade. Basically one of my standard tube amps with input and output controls so you can set the amount of tube/transformer overdrive and then tame the output level.
