:thumb: This is what i was looking for... :grin:if you use 4x 7812 you should lift the (single) voltage going into the four Vregs, not lift each seperate output.
Thank you very much
fotis
I don't know yet. I am going to check what is like to my ears. I am more pleasant with dynamics and super linearity. I hate some slow rate like snakes tube sounds or muddy, fat sounds etc.For start i think a CRCLC (point for 5687) to continue LC (point to 12au7) for each channel, but i am not sure. Do you have a better idea ? I would try a tube rectifier but i haven't such trafo for this. Maybe another time.what are you planning to use?
I found 2 big Solen MKP 22uf/400V , too. :wink:but improvements can be made in the PSU with the components you got. do you want me to draw up something?
I will try to find this tube from a friend . I have tons of thinks on my bench but no tubes . But i have a friend with a great tube collection. He gave me for Slowblow 5 JAN-5687WB by General Electric and 2 ecc82 by Mullard :grin:one day if you have time, you could try and use another tube than the 12AU7, the 6SN7
I am not sure that i understand. My Slowblow's prototype heatres powered by a LM338 adj for 12.6VDC.(use 12SN7 - same tube, but with 12,6V heater)
No this isn't the prototype 30' version but is still based on slowblow version :grin:do you build this in 30 minutes? Is this your version of the SloBlo?
How did you do the heater biasing? To which voltage do you bias the heaters? Which values at the resistors/the cap? Do you use the biasing as a bleeder for the HV, or do you use an additional bleeder?
Ole mentions on his site that you have a different design around the first tube?
