Rob Flinn
You should be using a TL783 for the 48v rail (i.e the reg in the top left corner in Whoops pic), The LM317 is a bad choice, if it gets shorted it will blow. The TL783 can handle a lot more voltage across it.
Rob Flinn said:You should be using a TL783 for the 48v rail (i.e the reg in the top left corner in Whoops pic), The LM317 is a bad choice, if it gets shorted it will blow. The TL783 can handle a lot more voltage across it.
moamps said:First measure DC voltage on phantom +48V output, if it's more than 48V, do not connect any condenser microphone.
then measure AC voltage on the same output (set your voltmeter to AC, 2V or 200mV ),
check the DC phantom voltage on XLR, pins 2 and 3 when phantom is on,
check the DC and AC voltage between pins 2 and 3 on input XLR,
report back.
Whoops said:Print the PSU schematic, follow it and measure and check each component one by one, highlight on the schematic all the components that measured correctly or are good.
Check all component values, sometimes people swap a 220R resistor for a 220K, or a 10uf cap for a 100uf cap or vice-versa, re-check that. Measure all diodes with the multimeter.
Check the PCB traces for solder joints between adjacent tracks or pads, check for colder joints also
Measure the voltages like Moamps said and also measure all the voltages that are in the layout provided by PeterC,
write your values underneath the written ones and show us all.
amaurythewarrior said:I think I might need a new multimeter, mine only does voltage and resistance... and DC mA
Khron said:... Or an LM317HV (good for 60v input).
Khron said:Would you care to show us a photo of your multimeter?
amaurythewarrior said:Sure, that's the one
https://www.bkprecision.com/products/discontinued/117B-analog-pocket-meter.html
Khron said:"Measures AC voltage"
Wonder what the "50 / 200 / 500 ACV" might be for... :
peterc said:Check the values of the resistors next to the Phantom LM 317. They should be 220ohms and 8k2.
Check the LM317 for shorts. On the ohms range, measure from pin to pin to make sure none of them is short circuited. Also check for shorts to ground from each pin of the 317.
The LM 317 is good about 36v difference between input and output, so if the tripler (input to the 317) is at 63v, then the 317 will be OK with 48v at the output.
If the output shorts to ground with the PSU on, then the 317 will fail.
amaurythewarrior said:Ah, no, you misunderstood me.
My point is +48v is direct right? I understand you measure it between ground and "+", but since you're asking me to measure AC I'm a bit confused. It's probably basic knowledge, that I lack. I have already measured AC, but I'm worried about doing something wrong if I don't do it properly.
Khron said:I'm quite sure the point of advising you to measure the AC on the phantom power rail was to see if and how much ripple voltage (ie. AC) is present. You were complaining about him there as well, weren't you?
amaurythewarrior said:Ah, I see, but just to be clear, this is to be measured between the same points (ground and positive?).
Complaining about "him"? AC ripple you mean? I'll be honest with you I first read about ripple recently, and I can't say I'm clear on what it is, other than it being something you don't want.
EDIT: okay, after reading more on the topic I think I found the answer and get the point.
Khron said:... Hence the thought of measuring the AC ripple on the phantom power rail.
I apologize for not being clearer, just put the instrument in the AC measurement position and watch what you will get at the DC output + 48V. The AC voltage that is actually hum is or can be superimposed on a DC phantom + 48V voltage.amaurythewarrior said:Excuse my ignorance, but how do I measure AC voltage on the +48v output? between ground and +48v as well?
