Gene Pink said:One thing to try, on your "modded" schematic, under the capsule is a grounded 6.8K in series with a 0.33uF cap to the capsule.
Measure the voltage across that 6.8K resistor, if it is anything other than zero, replace that cap.
The voltage drops on those 1M resistors means about 60uA DC current is flowing, and the only things downstream are supposed to be capacitors. Something is leaky, that current is going somewhere.
Gene
ricardo said:A quick glance at your modded circuit suggests the added 2.2nF and top 330nF will reduce gain by more than 50dB.
Also not sure what the bottom 6k8 is doing but it certainly introduces noise.
