NewYorkDave
I've been wanting to build a tube-based mixer for line-level signals. For the purposes of this discussion, let's ignore the question of whether or not this is a pointless thing to do and pretend it's 1955 :wink:
The classic approach of using lots of tubes and transformers and a low-Z, constant impedance mixing network is far from economical. So I've opted for a high-Z passive network feeding directly into the grids of tube booster/program amplifiers. The source Z looking back into any of the pots in a channel is 0-20K (depending on setting) and the mix resistors are 100K. The impedance of each mix bus--which depends on the # of channels connected and any other resistance shunted across the bus--will fall somewhere between 5K and 10K in my build.
The maxim of "ground follows signal" is easily implemented in a single-input, single-output system (e.g., preamp, guitar amp) but the best way to do it become less obvious in a multi-input, multi-output system like a mixer. The physical details of the bussing become particularly important in a high-impedance network. I've prepared three diagrams to show the options I'm considering. These are outlines, not detailed schematics, but they show enough to get the idea across.
PDF 1
PDF 2
PDF 3
Diagram 1 is, in my estimation, the best approach overall in terms of noise and crosstalk. Diagram 3 is much more convenient in terms of construction, and Diagram 2 is somewhere in-between.
In all cases, the thick bus lines represent heavy-gauge (#14) bare bus wire. Shielded, twisted pairs (diagram 1) are low-capacitance, "AES compatible" type. Coax (diagram 2) is small, low-loss video coax such as Belden 1855A. Connections from amplifiers to ground bus are made with #16 or larger hookup wire.
Comments invited :sam:
PDF 1
PDF 2
PDF 3
