ilfungo said:Is your test switch work well?
ilfungo said:Remove link between R40 and R41
Connect R41 and R42 ( + 4).
Mine one too but I expected definitely a deeper compression ..ilfungo said:Mine have full scale (GR mode) compression.
I did it many times, I have two selected 6bc8's from Christian Whitemore (propadiotubes) and also 2 good tubes (they probably work well too)ilfungo said:Could be a bad 6bc8 or some false contact on pcb.
Do you mean the jumper on the meter board? Yes I did, now IN and OUT modes show proper activity..ilfungo said:Have you corrected the ratio switch connections as suggest some post before?
ilfungo said:The unit seems to sound and work great
I'm only Hum problem but I don't know if it's normal...
Attached the noise figure misured some time ago...
The Hum come from the output, input only hiss and It's normal
Me not.. But I should try.. but I'm not sure if it really helps..ilfungo said:Hi Greebok
I don't have tried Hi mode... And You?
Oh.. That would be nice.. :ilfungo said:For now I can't make a saples becouse I can't go to my studio for virus situation...
I hope to be able to do it soon,,,
Potato Cakes said:Thanks!
Paul
Greebok said:Hey Paul, do you have any audio samples recorded through your 176? If it's possible could you share them please?
Potato Cakes said:How tight are your heater leads from the power transformer? I wound up adding DC heaters to solve any hum issues.
Paul
Potato Cakes said:All of of the vocals and kick drum were processed through one of my 176's. It's not a good quasi-scientific before and after comparison, but it's the only one I readily have.
Mine per layout is reversed...
Greebok said:OMG... it looks like "test 2" is actually "operate".. In this mode it works much better as the compressor itself.
PLEASE could anybody confirm that the test switch is actually inverted ???
UPD. Yes, there's another mistake in the layout, so the image of the test switch is inverted.
