janczmok
A bit of detective work So far i could match everybody correctly.
What changes were needed to make it work with JLC? I was curious and loaded the gerbers into their order page and I see the issue with the the cuts not showing up.Okay, needed to make some changes to the PCB order (cut lines) - hopefully right now. Also increased the PCB to 10.
Update (29/12): Primary check went thru. PCBs are in production, Secondary check brought issues. Costs might be slightly higher as we need a 4 layer not 2 layer PCB
X7R 0.1 for power rails to amps.
(Polys would work there too. Experimental? But I doubt you'd really hear much of a difference -- if any at all.)
C0Gs across op amps in feedback.
For caps in signal path maybe Nichicon (Muse) BP or Panasonic.
No need to be too picky about poly caps in side chain filters.
