My GSSL with Turbo board had been working flawlessly for several months, but upon running a mix through the unit last night, my stereo balance was ways off.
I ran a 1k tone through the unit, and one side is compressing considerably more than the other. I standard mode, the compressor works and each side compresses evenly, but the meter is showing much less compression than I would expect. The compression level of both channels is the same as the channel that is compressing less when in turbo mode (I'm only getting 4dB of compression, even with the threshold almost all the way down.
Swapped the THAT chips and get the same result.
I've read this thread, and noticed Script had a similar problem that resulted from blown diodes. Will check that tonight.
I keep reading about Keith's troubleshooting guide. Could someone direct me to that?
Craig
