GSSL add-on help thread
Script
Japan
How to add SSC board to GSSL -- proceed in steps.
- Confirm vanilla GSSL is functioning properly, including SC OFF switching, if you use it (otherwise hardwired for constant IN).
- Hook up power to SSC board and confirm correct voltages on IC sockets on SSC board without ICs inserted.
- Wire up SSC board from 47Ks and confirm SC filter functionality, ICs inserted. Could calibrate tilt now.
- Add and confirm EXT SEND and RETURN, if you want to use it.
- Last step, wire up relay-based SC BYPASS, if you want to use it (--personally I never did, cos first I never got the idea of a SC bypass [I prefer hard bypass] and second why that would need a relay--).
LNS
Active member
UK
It's working fine with back to vanilla, so will try adding it back in working through your steps.
I suspect the switch wiring was wrong.
desol
Regarding GSSL add-on's.
I said it before and I wanna mention it again. I wish someone would put all the fixes and add/ons into a single new GSSL board. Switchable Turbo/GSSL mode, HPF sidechain and a blend control. Would be really cool! :)
gyraf
Staff member
GDIY Supporter
Moderator
Aarhus, Denmark
@desol ,
I've been thinking of this, but my impression is that many builders seem to learn a lot from implementing these "wild" mods, there's a certain motivation connected to it, and a gradual progression of difficulty. A redesign would revert it to paint-by-numbers, not what we're really about..
/Jakob E.
Potato Cakes
Nashville, TN
If you are looking for an all in one board, you can get a case/kit from DIY-Recording Equipment or even DIY-Racked, which I use. I also have a GSSL with fixed turbo, quad VCAs, and a Cavendish I/O that I use in parallel with every drum track I mix. The latter of the options allows for one to take the first steps into making more complicated mods to this and other projects. As @gyraf said, the former option would just reduce the exercise to paint by numbers and remove the learning process all together. The GSSL board is probably the best circuit board for beginners to make a leap in their electronics knowledge after they successfully build one with modifications.
Paul
desol
@desol ,
/Jakob E.
I was looking forward to building another GSSL. I liked the first one I built. It was fun.
But I won't be building another one. It's way too difficult and time consuming to source down all these mod's, etc. There are a bunch of mod's scattered about, in different threads. I don't think I've ever seen a blend control for the GSSL.
I guess the GSSL is about learning (and 'spending' a bunch of time on mod's that hopefully will or won't work).
desol
I have one on mine... It's the Crush N' Blend kit.
Cool! It's actually a feature I need these days, the blend control. It would save fader's on my console. Something else that would be cool is a 'limit' ratio selection or 'crush' switch. So, in addition to the multiple (10+) various mod's/fixes I've seen for the GSSL, there is a blend after all.
Add a limit ratio, HPF side-chain, blend knob and bypass....onto a single new board....with the switch panel. Would be really nice!!
Script
Japan
The cool thing about the GSSL is that it invites people to experiment and implement all the mods they want. And naturally not everyone wants or needs all and every single mod.
Script
Japan
10:1 qualifies as limiting.
Or do you mean a control signal limiter, which limits the threshold 'depth' (and which would be one diode to ground, I think -- or maybe you rather need a feedback compressor?).
Or if you mean an output limiter, could look at DBX schematics and do one on veroboard.
Script
Japan
I do agree on the 'time consuming' aspect of the vanilla board. They are not the easiest boards to work on. Many malfunctions and time spent on troubleshooting could be saved by a more spacious board layout.
Another 'time killer' as of late are fancy bypass switches, it seems.
desol
Hey no....I just meant a 'crush' switch or button similar to the Smart C2 crush thingy. ie: extreme compression setting
petermontg
Ireland
Can someone point me in the direction of a gain reduction limiter circuit to limit the amount of gain reduction that could possibly work?
Or has this been done before?
Best
Script
Japan
Elysia mpressor, I guess, for FX compression. Unit still in production, so no schematics.
desol
Nowadays all of these things are pretty standard on many units. I just see no reason to delay a modern board for the GSSL with all the bugs, fixes, mod's, etc ironed out and included. People will still learn from putting it together, troubleshooting, etc...and can still add/modify/experiment with it, if they wanted to I guess. I tried to get the turbo working on mine but I wasn't able to. Something I couldn't figure out. Then I read about a distortion problem when it's in bypass that someone found, a long while ago, etc...and started wondering about my unit when it's in bypass. I ended up selling it, but actually I kinda miss it. I'm not sure the total number of things that could be improved/added. It seems pretty clear to me that this project is begging to be updated, and I think people would be excited/happy about it. That's all.
Script
Japan
The(G)SSL, even as vanilla, always struck me as somewhat unusual or 'non-standard' in that it is feed-forward mixed with some feedback.
Personally I never came across a 'bug' as such on the vanilla board or the turbo board.
I have never seen 'latching' here (easy fix though it seems), and SC Off, I'd agree, is a useless function (causing many troubles). Relay-based hard bypass is the way to go.
However, In general, I'd also say : the more complex the circuitry and all possible functions and combinations thereof for people to choose from and implement, the more complex the troubleshooting...
More space between solder joints? Desirable.
