Hi there,
I've been having trouble finding the 22uF 25v low ESR capacitors in Australia.
RS components have some that are 'low impeadence', I was wondering if that is the same as low ESR? ???
I really don't wan't to make another international order, it's getting expensive.
UPDATE: I found these at Farnell, Will they do?
Manufacturer: PANASONIC
Order Code: 8766762
Manufacturer Part No: ECA1EAK220X
* CAPACITOR, 22UF, 25V
* Application:Audio
* Capacitance:22µF
* Tolerance, Capacitance:± 20%
* Series:AK
* Voltage, Rating:25V dc
* Capacitor Dielectric Type:Aluminium Electrolytic
* Case Style:Radial
* Length / Height, External:7mm
* Diameter, Body:5mm
* Pitch, Lead:2mm
* Temperature, Operating Range:-40°C to +85°C
* Current, Ripple AC:55mA
* Temp, Op. Max:85°C
* Temp, Op. Min:-40°C
* Terminal Type:Radial Leaded
* Time, Operating Life:1000h
* Tolerance, +:20%
* Tolerance, -:20%
* Voltage Rating, DC:25V
Darren
