hotbaby said:is it normal that it does compress more on ratio 2 than on 10? seems to work reversed. is there a trick, flipping two wires or so?
I added the turbo, all other works awesome!
Maybe wrong, but it looks like you connected the safety ground of your IEC inlet to the transformers center tap by the violet wire and pcb 0V to case ground by the blue wire instead of a short connection between IEC and case (blank metal spot required for a safe connection, so scrap the isolating paint off in this spot). If anything on your mains voltage inside your box breaks, this 230VAC would have to run thru the blue wire - and thru your gssl - to finaly get to the safety ground connection at the IEC inlet. The blue wire between 0V and safety ground is not needed but YMMV.hotbaby said:Here is my finished working one:
Come on/out. Might be useful if you make it switchable ;Di m to afraid for writing the reason for the phaser effect
Yes/no/maybe/telephone joker.juan86 said:could this problem be solved by replacing the 10 ohm resisters leading to the regulaters 78l12 and 79l12 to 100 ohm or more?
