ytsestef said:
regularjohn said:
ytsestef said:
For all I know, it is mentioned everywhere in this forum that the ration DOES affect the threshold. This happens to everyone. My gssl does it too, but I read that it is normal ???
I just re-adjust the threshold each time I change the ratio to get the same amount of compression and keep the new ratio character.
Anyways, the controls seem to be stuck on 4:1, 10 ms Att., Auto Rel. with 4dB of reduction for me ;D ;D (sounds lovely)
Check a couple pages back in this thread where I posted a link for proper calibration procedures. If your GSSL is properly calibrated then there is no change in Gain Reduction or output when toggling between ratios. If you're using the resistance values as labeled on the pcb, then you will have the problem that you have. The values on the pcb are for the THAT2150 or DBX202. If you're using THAT2180 or 2181, then you need to change some resistance values. Go to http://homepage.mac.com/marten.thielges/gssl/calibration.html and http://diy.fischerworks.com/gssl_vca.shtml
yea, i changed the 3,9k to 5,1k and removed all the pin4-nc-related stuff but still there is some slight change. Anyway, I have an ever-so-slightly more annoying problem. I use the behringer meter with the 20dB scale (the one from diypartsupply) and have used the 2k resistor (as specified for 20dB scale meters) but still when the meter shows 4dB reduction, 2dB actual reduction happens, when meter shows 12dB reduction, 6dB actual reduction happens, etc. It is always showing double values from the actual ones. Should I try a 3,9k resistor in place of the 2k?
The 3,9K to 5,1K change is only for the audio-VCAs. The sidechain-VCA pin5 is connected to -12V and not to -15V.
For the ratio you change the 100K (used for DBX2150) between TL074-pin8 and TL072-pin6 to 120K or 127K (for That218x).
Take a look at the latest
gssl schematic, component placement, .. (still containing minor errors and discrepancies to pcb, like the 10Ks @ NE5532 non-inverting inputs, the mixed up 91K/750K @ auto-release on pcb, .., but getting closer). Use a 4,7K trimmer (wiper dialed @ center for 1st powerup) and adjust it for the needed value for your meter to match gain reduction with needle movement.
