Harpo
Sidechainfilterboard (SCF) Rin resistors R12 and R13 are 20K resistors. Wiring the DPDT switch as shown will parallel these (2x 20K in parallel=10K) for the lower drawn SCF board (connecting to the GSSL sidechain VCA) in Turbo mode operation only. For the upper drawn SCF board you can either leave one resistor (R12 or R13) out and fit a 10K for the remaining spot or keep both at 20K but wire link the L+R input of this upper drawn SCF board. This set this SCF summing amp to unity gain with Rfb 10K (R15).stereokillah said:hello Harpo, i will use supersidecahin fron Barclaycon need i sue the 20k and the 10 k on the sidecahin in?
and Why about this resistor.
thanx
If your kinda music or program material is more center related, the Rin resistor values for a constant power calculation [1/sqrt(2)] might fit better, so use a 14K as Rin for the upper drawn SCF board and a 27K in series between SCF board L-in and the right switch pole (20K || 20K+27K) instead, so both SCF boards have voltage gain of 0.707 or -3dB each in Turbo mode.
