peat said:Thanks for your consistent help regularjohn
I was a little worried theyd be too big.
I couldnt decide between the Nichicons and the Panasonics, what makes you say they are the way to go?
thanks again
regularjohn said:peat said:Thanks for your consistent help regularjohn
thanks again
No problem!
Well, for one thing the panasonics cost less! Panasonic FM's actually have the lowest esr rating between the FM, FC, and nichicon HE. The only thing is that the FM's are not available in as many capacitance values as the FC's or HE's. So I usually get what I can with the FM's and "keep it in the family" with the FC's...sounds silly, I know!
But I've built gssl's with fm/fc caps and with nichicon he caps, and to be honest, they're on the same level in terms of performance. I just get the panasonics now because they cost less. I also recapped my entire console with panasonic FM's, and like Chrome Heart said, the difference was startling! But that would have been the case with any high quality cap.
You could debate whether this cap sounds more open or whatever, but there's so many variables in a gssl (metal or carbon resistors; polypro, polyester, or metal film caps; electrolytic caps; how good the regulators do their job; which VCA's you use; etc) that you could go crazy trying to find the tiny subtle difference that one component will make. Bottom line is if you use good quality parts, like Wima's and low esr electro's, then you're in good shape (and you'll actually be using better components than real SSL gear has).
\phishman13 said:So I hope I haven't overlooked this, but I've tried searching for a bunch of different things with no results.
What edgewise meter is being used in the following thread?
http://www.groupdiy.com/index.php?topic=17039.msg197819#msg197819
It says Modutec later in the post.
It can't be this one can it?
http://www.mouser.com/Search/ProductDetail.aspx?R=ME-DMA-001virtualkey54100000virtualkey541-ME-DMA-001
The catalog says 2" and my case (which is exactly the same as the one in that post) has an opening about 1.4" wide.
I need to find that meter or make a new front panel for a different one!
Thanks for any info!
The primaries are right. The secondaries are also right. As long as 0V is on the middle pin, the other two wires can go to either point, it doesnt matter. So, green or blue on the secondaries can go to either outside pin.Sickhouse said:Hi Guys.
I've searched this forum and learned quite a bit, but could not find the answer to my question below. Please excuse me if this was answered before and I missed it somehow. I'm still learning, and I just want to be sure I do the next step properly.
I am a little confused about the mains hookup/power transformer. Since this is the dangerous part, I thought it would be best to ask my first question now. The first link is the transformer I have and the second is the hookup chart they sent me.
http://search.digikey.com/scripts/DkSearch/dksus.dll?WT.z_header=search_go&lang=en&site=us&keywords=amveco+62063
http://www.amveco.com/Miniature_Low_Profile_Transformers_2.htm
My guess so far is that the iec wires to the primary, which would be connect red and yellow to hot, black and violet to neutral, and ground goes to chassis. For secondary, I would run it split (+15/-15), connect brown and red to 0v, green and blue would be my +/- 15 correct? Also, I am wiring the transformer to the pcb as external, but the external 3 pin hookup does not specify the pinouts on the pcb or schems. I'm guessing that the middle is 0v. How can I figure out the + & - on the pcb?
Thank you so very much for the help. I'm having a blast so far.
Chrome Heart said:Just get one of these http://primeinstruments.com/products/panel_meters/model60_specs.htm Use a 1K meter resistor for 20db scale. And... it fits like a charm, even with the Par-Metal case.
I would suggest that you look very closely at the pads for solder bridges. This is an easy board for that to happen and I have found from my own builds its generally the problem. Also look at componant orientation and check for proper voltages at the IC's.Jazzboms said:Hi
Just started my first DIY project, a ssl clone, and have put together all the parts and wires, but the control panel dont work, no switches, no led. It makes nice clean sound, but only in bypass mode.
So.......... where to start?
The mainboard behaves the same with or without the control PCB connected.
I have to say I really enjoyed making this thing so far, and hoping to "learn by doing(and reading)" ;D
Thanks for helping
Espen
Jazzboms said:Just started my first DIY project, a ssl clone, and have put together all the parts and wires, but the control panel dont work, no switches, no led. It makes nice clean sound, but only in bypass mode.
Your reference voltage is 0V. Connect the probably black wire between your meters Com jack and this reference voltage on pcb. Probe voltages on pcb with probably red wire connected to your meters V jack. Depending on what you want to measure, set your meter for reading DC or AC voltages. In your case at first set for DC voltages to check if your supply is working correctly.Jazzboms said:Another beginner question. I measure from the +15V point on the main pcb, and out to the different points on the control pcb, yes???
You can do it! DIY!Jazzboms said:Yes, my power supply seems to be ok. 0V.
I think that the best thing is to find someone local who can help we with measuring and error seeking.
Thanks for helping.
