regularjohn
I agree...do the mod, leave the pin.
ytsestef said:I agree in using non-violent means to get there...
Leave the pin if it does not attack you. Do the mods, and you save your self from some soldering and some parts.
I built mine around THAT2180AL08-U's on my "project finished page" you can see exactly what I did:
http://www.groupdiy.com/index.php?topic=35352.msg433433#msg433433
Chrome Heart said:ytsestef said:I agree in using non-violent means to get there...
Nice work yt. How did you mount that B-ringer meter without the four screws?
Chrome Heart said:ytsestef said:Chrome Heart said:ytsestef said:I agree in using non-violent means to get there...
I used two screws!!
I cant see them on the faceplate.
I used two screws!!
Autophase said:I have just ordered my boards from Audio Kitchen, I am from the UK.
My question is, does gregs BOM (which looks very concise by the way- great work) have all the correct parts for the boards I've ordered from audio kitchen, and do i need to change anything for the ssl to work on UK mains?
Sorry if this is a really basic question.
regularjohn said:The fact that you're LED doesn't light could be one of two things...either your LED is in backwards or you don't have +12 making it to your control pcb. Check the voltages and continuity on the control pcb.
1.Threshold pot:
-The CCW side should read -12VDC. The wiper should have continuity to connection "F". The pcb side of the 47K connected to the CW side of the pot should have +12VDC
2.make up gain pot:
-CW side should have continuity with ground. CCW side should have +12VDC. The wiper should have continuity with the pole on the bypass switch that makes continuity with connection "E" when compression is engaged. So when not in bypass mode, the wiper of the make up gain pot should have continuity with connection "E".
3. When not in bypass mode, connection "C" should have continuity with the pole of the release switch.
Did you put the small wire jumper in on the control pcb? That's one I've forgotten before.
Be sure you wired the bypass switch correctly. If the leads are going to the wrong poles on the switch, it can still pass audio when in bypass mode, but won't work in comp mode.
Continuity of 'C' to pole of Attack when not in bypass mode.Sickhouse said:The only test listed above that didn't work was continuity of C to pole of release when not in bypass mode.
Harpo said:Continuity of 'C' to pole of Attack when not in bypass mode.Sickhouse said:The only test listed above that didn't work was continuity of C to pole of release when not in bypass mode.
Double check your bypass switch wiring.
Double check your bypass switch end-stop washer was set to pos.2 AFTER turning this switch full ccw with end-stop washer out.
regularjohn said:Autophase said:I have just ordered my boards from Audio Kitchen, I am from the UK.
I'm not familiar with Greg's BOM, but just make sure your transformer has a primary rated for your local ac mains voltage.
Also, if you're using THAT2181 VCA's, you'll want to do these mods:
http://homepage.mac.com/marten.thielges/gssl/calibration.html
The reason being is that the circuit was designed for DBX202, or THAT2150 VCA's. The 2181 is the newer generation of the 2150 and incorporates some of the previously needed external components into it's internal circuitry, so some resistance values need to be changed for the 2181.
Autophase said:Thanks,
I'm thinking I'll go for the pre trimmed version (2180)
Just looking around for transformers I found this http://www.airlinktransformers.com/transformer/0015215-open-style-toroidal-transformer-with-leads.asp
will this be right for uk mains?
