JayDIY said:But i have an almost continuous signal at the vu meter, increasing when i lower the threshold sensitivity
radiance said:JayDIY said:But i have an almost continuous signal at the vu meter, increasing when i lower the threshold sensitivity
Would be easy to track if you have an osciloscoop. Just follow the side chain pat, and see where the signal appears. If you don't have a osciloscoop start by checking for solder shorts around both tl74 and tl72 in the side chain path.
Do you also have this continuous signal when the bypass in engaged? Did you look at the schematic?
JayDIY said:The signal stops when in bypass...
And yes i looked at the schematic, everything goes where it should...
The only thing i didn't check is all the pins of all ICs, i only checked +- 12V and +- 15V on each and of course when i remove the tl074 in the sidechain detection circuit the continuous signal stops...
And no oscilloscope at all... :-/
radiance said:Signal still there when removing the side chain VCA?
radiance said:removing tl74?
removing tl72?
radiance said:My guess is...either a solder short or a wrong value part somewhere around the tl74....or both
