This thread is an amazing wealth of knowledge and is certainly the reason I have gotten as far as I have...unfortunately I am stuck.
I finished my gssl today (except for hooking up the meter) and tried passing audio. I have good rail voltages, all very close to their target.
I am getting huge output levels and distortion most of the time. I am using THAT2180's and followed Matt Fischer's instructions of removing the 50k trimmers, 1M's, both 10k's, the 68R's, changed the 3k9 to 5k1, and the 100k to 127k.
At first I mounted the VCAs with the 4th pin in place, after I bent it to the side I was getting more of the tone or track I was playing through the compressor, but a LOT higher output level. I realize this has been covered 1,000 times before...but I am correct in leaving the 4th pin out of the circuit right? (EDIT: I guess with the resistors out pin 4 makes no difference, I must have thought it changed because between powering the compressor up and down the output changed from low to high)
Sometimes the compressor is fairly quiet and will play the track (still distorted), other times it has 0dbfs noise and hum coming from it...even without an input. Bypass seems to make no difference, and make-up gain only does occasionally. If the compressor is acting a little better and playing at half-way reasonable levels, it seems that if I even touch the make-up gain pot the output skyrockets. Here is a signal trace I ran with a 0dbfs tone running
5534: pin 2: 3.2v
pin 3: 3.1v
pin 6: 13.9v
27k resistor before VCA:13.7v on first end, .5v on the other (is this right?)
VCA input: .5v
VCA output .1v (but -2.5 DC?)
5532 pin 6: .1 AC, (still -2.5 DC?)
pins 2,3,5: 0.0v
pin 1's read: 13.8v, and 14.9v
pin 7's read: 13.9v, and 15.1v
