GSSL HELP THREAD!!!
greyskull said:
Hi Guy's!
Excuse my very wet behind the ears ness here!
Can anyone recommend or supply me with a BOM for England For the Gssl?
I tried some of the others but struggled with a lot of the parts with most of the usual suspects as far as suppliers go over here (farnell, r.s etc)
Thanks in advance
Guy
I think I bought everything from Farnell except the PCBs (Gustav + Expat Audio), DBX 202C (nos black market), Sifam meter (Canford), 12 way switch for HPF board (eBay) and case (Parusha). If you build the 2180 substitute circuit you don't need the 202C, and the 12 way switch is only for the super sidechain.
I could send you my order history, but not all of it was for GSSL so you'd still have to do some detective work.
What are you having trouble sourcing?
Hi Guy
I dont have a BOM but could get you close...
I ended up with Rapid electronics for quite a lot of my stuff - I'll dig out the order details and paste onto a note later
some bits and bobs from Maplins - knobs/illuminated switches
THAT2180s from Profusion uk - you can order just 3 but they aren't cheap.
couple of orders i placed with Rapid below ....you'll need to wade through and check off from your GSSL list - I duplicated a lot of stuff to build a second and HPF sidechain too.
I had trouble sourcing pcb connectors and ribbon cables ( 5 way, 3-way and 10-way ) but got them from ESR electronics in Newcastle i think .
Turned pin sockets you can get from online robot hobby suppliers pretty cheaply ( as well as odd metal resistor values )
Cheers and good luck - its well worth the effort
Pete
RAPID codes below ...sorry for cut and paste format
1.
67-0416 2 2 Available 50k WR-085 Carbon Preset Potentiometer
RoHS
£0.0800 £0.1600 Reorder
2.
79-0215 2 2 Available 4 POLE 3 WAY PCB ROTARY SWITCH (RC)
RoHS
£0.7400 £1.4800 Reorder
3.
11-0682 5 5 Available 0.47uF 35V 5mm Tantalum Bead Capacitor
RoHS
£0.1000 £0.5000 Reorder
4.
11-1076 2 2 Available 6.8uF 35V 2.5mm Tantalum Bead Capacitor
RoHS
£0.1150 £0.2300 Reorder
5.
63-2445 0 0 Available 620k RCC 0.5W Carbon Composite Resistor
Out Of Stock
RoHS
£0.0000 £0.0000 Reorder
6.
11-1170 4 4 Available 100u 25V 105deg Radial Electro Capacitor
RoHS
£0.0840 £0.3360 Reorder
7.
23-3209 1 1 Available FUSED & SWITCHED IEC INLET PREWIRED 1.0MM (RC)
  RoHS
£1.8600 £1.8600 Reorder
8.
26-7693 1 1 Available 15A 20MM CHASSIS FUSEHOLDERREV SPIGOTSRC
RoHS
£0.4600 £0.4600 Reorder
9.
47-3190 1 1 Available WOO5 1.5A 50V BRIDGE RECTIFIER (RC)
RoHS
£0.2100 £0.2100 Reorder
10.
47-3292 1 1 Available L7812CV +12V 1A VOLTAGE REGULATOR (ST)RC
RoHS
£0.3200 £0.3200 Reorder
11.
47-3416 8 8 Available 1N4148 SIGNAL DIODE 75V 150MA (TRU) RC
RoHS
£0.0100 £0.0800 Reorder
12.
22-0059 2 2 Available 2.54mm Pitch 5 Way Crimp Housing PCB Connector Female
RoHS
£0.0700 £0.1400 Reorder
13.
63-1358 4 4 Available 3k9 MBB0207 0.4W Precision Resistor
RoHS
£0.2000 £0.8000 Reorder
14.
47-3298 1 1 Available L7912CV -12V 1A VOLTAGE REGULATOR (ST)RC
RoHS
£0.4000 £0.4000 Reorder
15.
63-1508 3 3 Available 20k MBB0207 0.4W Precision Resistor
RoHS
£0.2000 £0.6000 Reorder
16.
08-0040 1 1 Available 10pF 2.5mm Ceramic Capacitor
RoHS
£0.0220 £0.0220 Reorder
17.
11-1426 2 2 Available 1000u 63V Radial Electrolytic Capacitor
RoHS
£0.8400 £1.6800 Reorder
18.
08-0925 2 2 Available 22pF 2.54mm NPO Ceramic Capacitor
RoHS
19.
08-0930 4 4 Available 33pF 2.5mm NPO Ceramic Capacitor
RoHS
£0.0700 £0.2800 Reorder
20.
08-0940 9 9 Available 100pF 2.5mm NPO Ceramic Capacitor
RoHS
£0.0700 £0.6300 Reorder
21.
22-0064 1 0 Available
1 on Back Order 2.54mm Pitch 10 Way Crimp Housing PCB Connector Female
*non-stock item, available to back order
RoHS
£0.0900 £0.0900 Reorder
22.
22-0515 1 1 Available 10W SINGLE ROW PCB HEADER PLUG RC
RoHS
£0.0600 £0.0600 Reorder
23.
47-3301 1 1 Available L7915CV -15V 1A VOLTAGE REGULATOR (ST) R
£0.3600 £0.3600 Reorder
24.
22-0510 5 5 Available 5 W SINGLE ROW PCB HEADER PLUG (RC)
RoHS
£0.0500 £0.2500 Reorder
25.
63-1484 3 3 Available 15k MBB0207 0.4W Precision Resistor
RoHS
26.
47-3554 1 1 Available L7815CP +15V 1A PLASTIC V REG (ST) (RC)
RoHS
27.
63-1040 4 4 Available 120R MBB0207 0.4W Precision Resistor
RoHS
28.
63-1296 2 2 Available 2k MBB0207 0.4W Precision Resistor
RoHS
£0.2000 £0.4000 Reorder
29.
63-1536 3 3 Available 27k MBB0207 0.4W Precision Resistor
RoHS
30.
63-1640 1 1 Available 82k MBB0207 0.4W Precision Resistor
RoHS
£0.2000 £0.2000 Reorder
31.
63-1650 4 4 Available 90k9 MBB0207 0.4W Precision Resistor
RoHS
32.
63-1750 1 1 Available 560k MBB0207 0.4W Precision Resistor
RoHS
33.
63-2436 3 3 Available 270k RCC 0.5W Carbon Composite Resistor
RoHS
£0.1280 £0.3840 Reorder
34.
68-1180 2 2 Available 50k P260P Linear Rotary Potentiometer
RoHS
£1.6500 £3.3000 Reorder
35.
79-0205 2 2 Available 2 POLE 6 WAY PCB ROTARY SWITCH (RC)
RoHS
36.
82-0050 1 1 Available TL072 BI-FET DUAL OP AMPLIFIER (RC)
RoHS
£0.3400 £0.3400 Reorder
37.
82-0054 1 1 Available TL074 BI-FET QUAD OP AMPLIFIER (DIL) RC
RoHS
£0.5000 £0.5000 Reorder
38.
82-0724 2 2 Available NE5532P DUAL LOW NOISE OP AMPLIFIER (RC)
RoHS
£0.3600 £0.7200 Reorder
39.
82-0734 4 4 Available NE5534P LOW NOISE OP AMP (RC)
RoHS
£0.3900 £1.5600 Reorder
40.
67-0410 1 1 Available 5k WR-085 Carbon Preset Potentiometer
RoHS
£0.0800 £0.0800 Reorder
41.
11-1160 14 14 Available 22u 25V 105deg Radial Electro Capacitor
RoHS
£0.0315 £0.4410 Reorder
42.
10-3260 30 30 Available 100nF 63V 5mm Polyester Box Capacitor
RoHS
£0.0500 £1.5000 Reorder
43.
88-3353 1 1 Available ENCAPSULAT TOROID 15VA 15V+15V 0.5A(RC)
RoHS
£11.5700 £11.5700 Reorder
44.
20-1700 3 3 Available E3MSC straight solder cup XLR plug
RoHS
£2.1800 £6.5400 Reorder
45.
20-1706 3 3 Available E3FSC straight solder cup XLR socket
RoHS
£2.4800 £7.4400 Reorder
46.
26-0382 1 1 Available 315MA 20X5MM ANTISURGE CERAMIC FUSE (RC)
RoHS
£0.1400 £0.1400 Reorder
Totals    £51.00 £51.00
RoHS
2.
RoHS
3.
RoHS
4.
RoHS
5.
Out Of Stock
RoHS
6.
RoHS
7.
  RoHS
8.
RoHS
9.
RoHS
10.
RoHS
11.
RoHS
12.
RoHS
13.
RoHS
14.
RoHS
15.
RoHS
16.
RoHS
17.
RoHS
18.
RoHS
19.
RoHS
20.
RoHS
21.
RoHS
22.
RoHS
23.
24.
RoHS
25.
RoHS
26.
RoHS
27.
RoHS
28.
RoHS
29.
RoHS
30.
RoHS
31.
RoHS
32.
RoHS
33.
RoHS
34.
RoHS
35.
RoHS
36.
RoHS
37.
RoHS
38.
RoHS
39.
RoHS
40.
RoHS
41.
RoHS
42.
RoHS
43.
RoHS
44.
RoHS
45.
RoHS
46.
RoHS
Hi! i'm new here and just built my first gssl, got some problems with it though, it doesn't work (yet)
- I used a regular 1mA meter, it doesn't respond to anything
- compression is not working (turning attack, ratio, treshold, release don't make any difference)
- when the release lorlin in turned all the way to the right, i get a subtle distotion and a hum, all other setting don't
Make up gain works just fine and all audio that goes thru it is crisp and clear for that matter.
Any help at all would be much appreciated...
after some troubleshooting i luckily managed to fix most problems.
The only thing bugging me now is the release lorlin switch, the most left and most right settings, both give me distortion.
Everything else is working topnotch!
Thoughts anyone?
did you make sure you did the small jumper on the control pcb ?
many people had sam symtoms by leaving this out
Goos luck
Pete
Thoughts anyone?
These are just passive CR filters.  So you should be able to disconnect them from the main board at point C and D. You should be able to test them stand alone by connecting a (low frequency) pulse generator at point C and monitor the output at point D with a scope (no need for power on the main board for this test).
You could also try injecting a small negative DC control voltage (via a 100K resistor) into point D on the main board instead of the connection to the output of the filter, to make sure your VCA is not the source of the distortion, although that's unlikely if your make up gain is working correctly.
Have you inserted all the wire links on the switching board? Have you inserted the tantalum electrolytic caps in the correct orientation (+ve pin towards ground, because the control signal is -ve wrt ground)? Have you also checked whether the two caps on the CW setting are in parallel with the correct resistor? (they were marked incorrectly on my board => u47 should be in parallel with 760K & 6u8 in parallel with 91K)
[/quote]
both the schematic pdf at gyraf and my board say that 750k is next to (parallel) 6.8u and u47 is next to 91k.. so that's the way i soldered it...  where does it say that has to be swtiched then?
i double checked, all tantalum electrolytic caps are in the correct orientation.
btw what's up with that annoying captcha business every time i post?
synnys - yes the wire link next to the meter connection - have you checked for bad joint ?
Rgds
Pete
ok release distortion is solved, i think i had the wrong pin setting on the lorlin switch.
still got 6.8u next to 750 and 91k next to 47u though.
only thing now is that when switching to bypass mode, the make-up gain remains active, in other words it distorts when i apply a lot of make up gain. is that normal?
Rgds
Pete
i did actually overlook this wire, but that was a few days ago so i got that fixed before posting here ;)
you can take the make-up gain out when switching to bypass by using a second pole on the bypass switch (use 2x6 or 3x4 if you want a bypass LED). That cuts the added voltage that comes off the wiper of the 50K make-up gain pot to the control voltage going to the VCA's. This is point "E" on the schematic...
Now you've got me confused.
The  original board schematic has the 6u8 in parallel with the 750K and the .47U in parallel with the 91K. Whereas the redrawn schematic has them the other way around. I guess the original must be correct, which means I've got to check my builds.....
Hello ppl,
I'll start my SSL. Today I asked the PCB to Chef. This is the list of components correct? http://www.gyraf.dk/gy_pd/ssl/ssl_complist.htm
I ask because I saw this board a list of some differences. example:
site list
78L12 1pcs DC REGULATOR 12V/0.1A POS.
1pcs DC REGULATOR 12V/0.1A 79L12 NEG.
forun, the long time post
AN78L12 12V 100mA TO-92
AN79L12 TO-92-12V 100mA
thanks
Hugo
Hi Guys,
I was posting in the wrong corner of the lab, sorry for that!
As a first-time builder of the GSSL unit I am trying to get the right parts together.
There are many builds of the NE5534 op amp.
Trying the search option of the forum doesn't bring me to any shoot-out of the brands and types.
It's my first DIY project so hopefully it's not a dumb question to ask for the best NE5534 or substitute to go for. Between the brands and types things like slew rate and operation temperature differ.
Thank you!
Martijn
Lacrosse said:
Hi Guys,
Thank you!
Martijn
I think you are over thinking this one.  The NE5534AP and NE5532AP worked well for me.  If you wanna know which one sounds best just put sockets in and buy different brands of op amps and decide for yourself, (thats the fun part anyway ;)) they aren't that expensive so you have nothing to lose
