Problem:
I had the SSL working, (it ran for hours, I love it!, classic buss compresser) it had this problem at first, so I'm assuming
there is a short, but I'll be darned if I can find it.
Details:
If the control board is disconnected, everything seems to work great,
+6 db great quiet auido passes flawnessly, nothing how runs great.
Plug in control board and not the makeup gain pot, but the threshold pot,
if turned to right, makes the led go dim, now I saw gyraf make a reference to the makup gain pot causing the led to go off, but I can't find
that thread or a similar one that specs the threshold pot doing that. I've done some voltage traces back and foreth between the tl074 and the control board pins, check continuity on the cable and looked for the short, if the threshold pot is turned all the way down, in bypass mode, it almost works and passes audio, but anything to the right almost immediately causes the a large hum and no audio. and the voltage to drop to about 4v where it was 6.5.
anything sound familar?
on most of the pins and -10 where it was -12 before on the pot.
