[quote author="Hulk"]Could someone help me identifing these components for the SSL - I have tried the net but I didn't find anything:
1: The long arm is the posetive one right??
2: Don't know that one either :? (Is that one of the 25 100n 5mm 63V polyester capacitors(it says .1K 63 on top) for the -||- (.0) symbol on the PCB??
3: On these ceramic's it says: 10 then a little distance and then a 1 - they also have the letters MQK - are these the 10 ceramic's called (100p 100V 5% Monolithic) for the -||-(100p) symbol on the PCB??
4: On these ceramic's it says: 33 - are these the four 33p 100V 5% Monolithic for the -||-(33p) symbol on the PCB??
5: On these ceramic's it says: 220 and HQ J - are these the two 22p 100V 5% Monolithic for the -||-(22p) symbol on the PCB??
6: On this one it just says: 10 - is that the 10p 100V 5% Monolithic for the -||-(10p) symbol on the PCB??
Sorry for the stupid questions :roll:
I would be very greatfull if someone could help Thanks!![/quote]
Just a few more questions :roll:
I have used "left over" wire from the resistors between the connections on the SSL PCB (black rings) - is that OK or do I need to use some kind of magic wire :green:
Within the yellow rings there are two different letters, one is called 100
P the other is called 100
p is there a difference between the capital letter P and the other p.??
