Hey guys,
Been lurking around here for a while and was enticed into starting on the GSSL project even though I don't know jack about electronics and can barely solder. I have absorbed as much from this site the the Gyraf site as I can handle, but some things go over my head. I managed to get the PCBs stuffed for the most part, but I am hung up about a few things. I think they have been explained before, but I am too dense to comprehend; so dumb it down for me.
Here is the data on the toroidal transformer I have: Amveco62063
http://rocky.digikey.com/WebLib/Amv...Series Low Profile Miniature Transformers.pdf Wiring for USA voltage. Now I think I solder the yellow and the red together or maybe solder them to the PCB in like the middle 2 holes on the right side of the transfmr section. Then maybe I connect the....OK I have no clue. Everyone seems to do it differently and there are two possible sections to connect to in the first place. :sad: I'm also bound to hook up the IEC plug-in wrong, so I would appreciate some guidance there as well. And where the board is silkscreened +15V above -15V, are just normal jumpers supposed to go there or is that just a test point or what?
On a related note: how does the on/off switch hook in there? Does an extra wire off the transformer go to it or does it hook to the plug-in somehow?
And on the subject of switches, which way do the darn things go in there? The ratio and the attack switchers seem to go in right side up (turning the knob to 1, 2, 3, etc is about where it should be), but the PCB holes for the RELEASE switch are flipped around and I'm not sure which way to mount the switch. There are only two choices I guess, but it would be nice to know the right one without soldering it all up wrong first.
One last minor thing before I quit bugging, I can't squeeze in the 5-pin terminals that go the XLRs without unsoldering some stuff. Should I just forget them and solder direct to the board, or will that be a regrettable decision?
Soooo sorry, but I would really like to make this work despite my own stoopididy. Appreciate any help, and thanks for all the info that has been provided already. If it helps, I used this parts list: http://members.cox.net/capstanrecording/SSLCloneParts.pdf (thx greg) Dang already
Don't flame?
