Potato Cakes said:Check all of your voltages with the ICs removed. You also probably have something missing/soldered incorrectly on the ratio board.
Paul
angelo2979 said:Many thanks to you!
Can you help me spot these components? if there's anything else to look at other then those 1M8 and 510K resistors... I've checked these and they do look good, I may just try to reheat the joints.. also resistors around the TL074 look correct.
.. just to be sure I get it correctly.. The fact that I'm having more compression on 4:1 should mean I have more then desired resistance to the amp? Also, even just by looking at the switch and component position, am I right assuming there's no possible way that 10:1 and 4:1 are inverted, right?
Thank you again
angelo2979 said:Well, just tested with the treshold set at maximum so that there should be no compression.
Again, 2:1 and 10:1 all fine - but 4:1 gives me obvious compression and the meter jumps between 4 and 8 !!
angelo2979 said:2. Metering. The meter shows like double the actual gain reduction. I have a 1mA meter and the suggested 2k resistor on PCB (for 20db scale). And the meter's own adjust screw doesn't seem to help - looks like it can't cover that range. Maybe it's just a broken meter.
Does this work correctly without the Turbo board? If the answer is yes then this something that should be asked on the GSSL add on thread.
aaruel said:Alright, I had time to flip the wiring and it has the same behavior.
LEDs turn on in the push buttons when switched
Audio gets passed through, both channels work great and have ZERO noise![]()
Turning on the compression (deactivating the bypass) still does nothing, also it might be good to mention the makeup gain does nothing. Probing the voltage of the makeup pot, it goes from 0V-12V just fine, so I'm not sure what's going on. Anyways, something that might be going on, I'm assuming there should be a voltage coming to "ON" and "OFF" and coming from "COM" so it can be managed by the switch. Well, there isn't a voltage coming from "COM" or going to "ON" or "OFF" . Looking at the schematic, COM goes to the ATTACK rotary, for some reason. Does this mean the switch isn't working?
Potato Cakes said:You are sending power to both LEDs when the unit is on in that wiring scheme. You need either a separate power source for the compressor in LED or use the relay diagram that was posted somewhere earlier in this thread.
Paul
