1wildthing
- Joined
- Jan 27, 2021
- Messages
- 70
Gustav
I’ve tried to compare the behavior of my gssl to the waves plugin in order to understand the differences. Threshold wise from the center scale to full CCW the behavior is similar and even the meter reacts in the same way.
Your unit should not react when threshold is set above audio level - there is no "compressor to one side/expansion to the other" functionality, only compression over the set threshold.
Sounds like you have something weird going on, but we would need feedback on what happens to help.
Gustav
Ok Gustav I’ve tried to compare the behavior of my gssl to the waves plugin in order to understand the differences. Threshold wise from the center scale to full CCW the behavior is similar and even the meter reacts in the same way. However when the pot moves from the center to the right in CW direction the meter immediately goes to 0, the compression disappears and bypassing the effect the sound is the same. Moving threshold pot even to full CW makes no difference and even on hard settings of other knobs the sound doesn’t change.Your unit should not react when threshold is set above audio level - there is no "compressor to one side/expansion to the other" functionality, only compression over the set threshold.
Gustav
I’ve tried to replace the threshold pot but nothing has changed.
Any idea?
