[quote author="Luny Tune"]I know how you can get confused about the funny lines there. I was too. But have a look at the schematic and PCB layout you can find at gyraf.dk.
There you'll discover that the lines are actually "intentional leftovers" from the description and drawing about how you can either solder in a short right there or leave it open when you connect the bypass switch. (See the mentioned documents for explanation!:wink
The On, Off, and Com holes are for the bypass switch to be wired to. And since you got confused over the same thing I did, I might as well tell you the answer to the next thing that confused me a bit.
Remember that "On" means
no compression, and "Off" means
compression since we're talking about the Bypass switch being on or off.
You probably got that already, but just in case...:wink:
To give you an idea about exactly HOW those switches work symmetrical, take a good look at the way the bypass switch is wired in the PCB layout .pdf file. Note how the 4x3 switch is described as having A1, A2, A3, B1, B2, B3, C1... pins but on your actual switch the pins are labelled 1-12. The 1-12 is what throws one off as the other way gives you a much better idea about how they're constructed. When in position "1" the middle pins A, B, C, D are connected to A1, B1, C1, D1 respectively (which will on your actual switch be pins 1, 4, 7, 10)... Get the picture?
Understanding these things to some degree gives you power to alter the DIY projects to your likings. You'll find that when you get a good grasp on it, it will also be easier for you to find replacement parts for one project or another, as you will know what functionality to look for.[/quote]
Excellent response, thank you very much. I love when people give me a response that I learn theory from instead of just 'how to do it'! Thank you very much.
So to further elaborate, can I use a DPDT switch in the situation? In the bypass state I should have "ON" and "COM" shorting and in the compressing state I should have "OFF" and "COM" shorting? Is this correct?
One more question about switches, this time the powerswitch. Do I just put a SPST switch in series between the transformer and PCB (on POS volt?) or do I need a DPDT (both POS and NEG)? Or does the switch go between the IEC and transformer in one of the previous fashions? And what size fuse should I be using?
