stitch-o
Here's my progress...
The only thing I am stuck on is about the relay bypass as connected on the original GSSL FP ratio/attack/release board.
Right now, that nest of orange wires in the bottom picture goes from the ratio/release/attack board to a relay to a lighted bypass pushbutton on the FP.
On the SSC, the potA, potB, COM, OFF, and ON seem to go to those same points on the GSSL FP board.
My question is, when wiring in the SSC, do I entirely remove the current lighted bypass switch scheme and, instead, wire the
potA, potB, COM, OFF, and ON from the SSC to those points on the FP board and then install the "In SW" switch to a SPST and "IN LED" indicator on the FP for global bypass?
What is the "Meter Led" for? I have a sifam with no lamp.
Should I just let that connection point hang open on the SSC or does it need an Led to complete the circuit?
Thanks doods!
EDIT: after rereading this entire thread, I think the answer is 'yes, to the bypass wiring question' to the above but I'd dig having an experienced opinion.
RE EDIT: after going through the docs again, I see that the answer is yes.
The two sided layout (one side is relay bypass and the other is thrust and HPF) is the key.
Cheers!
