damien
Hello everybody. I am currently working on a DIGIKEY BOM for the supersidechain filter board.
What relay should I buy at Digikey ?
Is this one alright ? http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=Z110-ND
I will use my G-SSL only in TURBO mode. Though, I don't need a switch to select from TURBOmode/GSSLmode.
>>> Is this kind of rotary selector alright to select the HiPass Filter Frenquency for the 2 boards ?
Do you think this one is ok ? http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=451-1013-ND
It's very expensive ! 25CAD. Does anyone have a good model ref. from digikey but less expensive ?
Do you think I can solder the wires from a single deck lorlin selector to the pair of SSC board Frequency ?
I read somewhere in the forum that it will be easier to switch and toggle the BYPASS LED of the switches with the supersidechain board.
I will use the beautiful Nikkai UB2 switches to power on and to bypass the compressor. What type do I need to use ?
Tell me if it will be alright :
for the Power Switch : SPDT / Silver Rated 5A @ 125/250V AC
for the Bypass Switch : SPDT / Gold Rated 0.4VA max @ 28V AC/DC max
Switches are really expensive, so I don't want to go in a wrong way. I'll wait for your advices.
Thank you in advance for your precious help.
Damian
Damian
