Heheheee I already ordered 2 board ;D
The thing is, I need to be absolutely clear about what I'm going for. Hence my repeated questions on the different mods
My first idea was to build a dual SSL comp with a switch to be able to use it as A/B or as stereo. Frank at NRG told me I couldn't do this with one board because of the Gyraf design. So I thought I could use 2 boards, building one board "normally" and only one channel on the 2nd board. In the "link" position, the switch would be in true bypass mode (letting the 2nd board out of the circuit) and in the "A/B" position the switch would change the path of i.e.: the Right channel from its input XLR to the second board input. The outputs of the Right/B channels could be combined in a Group Output on the same XLR connector.
But then again, after looking through the forum for other projects that would have the same idea, I thought I might just build 2 units and be able to have 2 mono + 2 stereo GSSLs!! Yes!! 8)
Then I found out about the Expat mods and the Super Side Chain. And then everything got blurry.... ???
I apologize if I am a bit of a PITA asking questions, but I still have a couple of "dark zones" in my mind regarding this
1) I understand Sidechain as a feature that makes the compressor process audio responding to an external signal. This should imply a physical input commonly labeled "key in". I can't find this input. Am I blind, what am I missing or where am I wrong?
2) I thought that the Turbo mod "adjusted" the way Jakob's circuit behaved by outputting the same GR whether using only L, R or L and R. I never associated it with a Sidechain feature. Again, am I blind, what am I missing or where am I wrong?
Thanks again to all of you for your time and patience
