Echo North
Matt C said:reviving an old thread here for a question about the Hairball 1176 enclosure/kit. I'm having a tough time sorting out exactly how the zero set 2k pot is supposed to be mounted on the front panel (doesn't seem possible to set the pot at a proper distance from the front panel hole). Is there any trick to doing this using the provided hardware, or is it just a matter of going down to the hardware store and getting a handful of thin washers to tweak the spacing?
anyone have a closeup picture of how theirs is mounted? my enclosure is newer and has the longer (1/2"?) zero mount standoffs, so the information in mnats' first post in this thread doesn't really apply anymore.
Check the first post in this thread. If you can get another 3/8" shaft nut you can use a nut on either side of the bracket to dial in the distance.
Mike
