seavote
I've taken the M1 schematic available at john hardys' web sight and stripped away the ground lift,phase switch etc and came up with the schematic posted below.
Schematic edited 10/23/
10/27
will the circuit work as drawn??
the original can be found here:
http://www.johnhardyco.com/Schematics/MPC-1_Schematic.jpg
this schematic is linked by me to the prodigy pro audio forum with Mr. Hardys' permission on a one time basis.it may not be altered in anyway or used on any other forum without Mr. Hardys' permission. permission is not given to copy it to any other location and link to the schematic there.
i've kept the component numbers in my stripped down schematic the same as in the original to avoid confusion when comparing the two. i'll be using an mnats 990 from one of ptowns kits, a stepped attenuator as in the hardy M2 and U2 will be an analog devices OP97. i just relized i did nothing with the OTs' (-) leg on the primary side.should this just go to ground? thanks for any help and /or suggestions
10/27
