b3000
Member
Cable: Mogami W2932 Analog 8-Pair
Techflex: 1/8" Techflex
Shrink tube for each channel: 1/8" 3:1 Techflex Shrink Tube
Teflon tube for bare drain wire: Teflon tube (You can also use shrink instead)
Hot Knife: HKB0.00WH Hot Knife
First I determine the length of Techflex needed for each channel in the fan-out.
I've made cables with Techflex for years without one, but using a hot knife to cut the flex is ideal. You don't get fraying. If you don't have one, just make sure you put enough shrink length and use 3:1 shrink ratio so you don't get that frayed mess from the shrink slipping down. (the right size and 3:1 is the key to the shrink not slipping)
I always put 1-2" of shrink around the outer part of the multicore where the Techflex covered fan-out ends.
After that, I prep and tin the wires for XLR or whatever connector I need.
Then I always put 1/8" 3:1 shrink over the Techflex on the other end near the connector. I've never had any issue with a connector going over that. Actually, the connectors seem to get a better grip with the tube, plus if you don't have a hot knife that tube is going to keep you from getting a frayed mess.
Those red shrink pieces on the ends are labels. I just write on them with an industrial Sharpie. There are probably better fancier ways to do labels.
I like the Techflex because it seems to give those thin fanout lines a bit more protection, plus they seem to be easier to untangle with the flex than without it.
