pahstah said:and others that would be too expensive for me to buy in advance (transformers, inductors).
Whoops said:The transformers you used are from Cinemag (transformers) andfrom Audiomaintenance (inductors)?
If so it's pretty easy for a builder to buy them separately
Whoops said:So at the moment,
input tx from Sowter (Europe) - you can also source input transformers from Cyril Jones/Raindirk, he sells Lustraphone exact Clone transformers
http://www.raindirk.com/lustraphoneTransformersRaindirkAudio.php
output transformer EA2623 from Capi (US) , many other options also for this application.
Probably people from Europe would prefer to source the In and out transformers and the inductors all from European sources.
And the US build from US sources.
How about the source for the inductors you're using?
agree, this would be a good optioniprovlek said:AVDAUDIO 2623 transformer sound great....
pahstah said:about Cyril Jones' transformer I'd ask dimensions before order it because I'm not sure it will fit
Whoops said:I can measure mine when I get back to the workshop.
Probably some creativity is needed to make it fit.
TwentyTrees said:Thanks Whoops, that would be helpful. I was also under the impression they were too big to drop in for a 500 series module
Whoops said:Nope, they're not to big for a 500 series module.
This transformer, contrary to the Sowter one, is made with the same Specs as the original Lustraphone transformer.
pahstah said:Whoops, that module in the picture is not a 500 series module, it is wider, 40mm or more.
I will take the measurements and will let you know in case it's useful.
